Are kia stinger front wheels smaller that the rears
Status
Not open for further replies.
GuyManDude
Central NJ
Hi all my wife has purchased a 2020 stinger and has told me the the car runs with different sized wheels ie the front wheels are smaller than the back ones, as we live in different towns I have not seen her new car so cannot say if she is being truthful
I have a 2020 GT1, and your wife is being truthful about the size of the tires on her vehicle.
O.E.
225/40-R19 Factory front tire
19’’Wheels
O.E.
255/35-R19 Factory rear tire
19’’Wheels
Staggered set up.
Yes this is true, what Glen stipulates is what we have here. You won't be able to rotate your wheels. As said its called a Staggered set up. If she's just bought it check the tyre pressures. In transit they over inflate the tyres. They are recommended as 36psi fronts 38psi rear. I run slightly higher 38 front & 40 rear.
sounds like a perfect marriage .......................bawaaaaa :laugh: :laugh:
OEM staggered front 8" wide, rear 8.5" wide.
I run currently in the mid 40s psi. The reason being: experimental: to see if I can even up tread wear. My previous set of tires wore down the outer edge; the middle tread still had 3-5mm.
Smart enough to find a Stinger discussion forum.
Not smart enough to look up vehicle specs.
Posts in "Non-Stinger Talk" forum section.
:rolleyes:
No surprise they live apart..
T
hank you very much I appreciate your help
:rolleyes:
You are an oxygen thief
You are such a tosser
I think W.C was having a tongue in cheek joke. I don't think it was meant mean spirited. Us old guard pay out on each other. Being a newbie you probably saw it as an attack. Hope that helps.
......................I dont really care , but thanks for having my back mate !! he should toughen up a bit or he'll get destroyed here ( av8.......................)
..............it always surprises me that some dudes are sensitive and thin skinned .................... , maybe it was just a bad hair day ................................just going for a laugh mate, lighten up ...............wanker ! :laugh::laugh:
..............it always surprises me that some Aussie dudes are sensitive and thin skinned .....................you're not living up to the Aussie reputation , maybe it was just a bad hair day ................................
What has nationality got to do with this post, its really disappointing to read this.
I noted a few weeks ago when someone (Import Shark guy) made offensive comments about Canadians & that was not received very well but I don’t recall any Aussies having cheap shots about “sensitive or thin skinned“ Canadians.
This is a car forum, most of us are here for a common reason & that’s to share & gain information about all things Stinger.
Let’s just leave cheap shots about the nationality of a member out of posts especially when it wasn’t even in the subject matter, to me you criticised the flag he represents not for his comments.
to you any any Aussie that is offended I truly apologize ! I'll edit the post
the O2 would have to belong to someone first my dude. Your first post was a slowww pitch what did you really expect
Listen here drongo, I had a question as I do not own a Kia my wife does so the info asked for a legit, if you think it is fun to bait other people you’re a total waste of space
you got your answer , move along
Status
