Drudge
Anyone make or is developing headers for our platform? I'm assuming a shorty tube header would work best with our turbo engines. Any insight would be appreciated.
The exhaust manifolds are built into the cylinder head
So a higher flowing header is pretty much impossible.
Yes bro I love the way you said it.The volumetric efficiency of the headerfold is matched to the turbo. And, the proximity to the exhaust ports minimizes lag. So, putting a traditional manifold on (not that you have much room to do this) might actually negative impact.
This thread is from the early days of the Stinger and has some incorrect info. The Stinger doesn't have exhaust manifolds integrated into the block (and it would need to be the cylinder heads anyway).We were looking in the engine bay and I pointed at the turbo and said “see that’s one of those tiny turbos, it’s basically integrated into the sides of the block leaving pretty much no air flow travel.” I said “they’re small but there’s practically zero turbo lag because of this design.”
Hey thanks for that, I’m surprised I haven’t seen this video.This thread is from the early days of the Stinger and has some incorrect info. The Stinger doesn't have exhaust manifolds integrated into the block (and it would need to be the cylinder heads anyway).
What it has are exhaust manifolds integrated with the turbo housings, and the main benefit is probably assembly. The turbos spool very quickly due to both their size and how small the manifold/housing necks down, but this also becomes a major restriction up top, hence guys short-shifting at 5800.
The bigger downside is that you can't easily upgrade the turbos, because the exhaust restriction will still limit flow, unless you replace the entire manifold/housing ($$$). This video shows the manifold/housing, and talks about the restriction starting about 3min in:
External wastegates would be a partial measure, as they would relieve back pressure buildup, but also throw away that energy vs. using it more effectively. Welding a larger diameter section in place would seem like the obvious workaround, but I haven't seen anyone do that.Anyways now I’m curious, the turbo housing/manifold in a larger diameter cast like he was saying, Is it on the market? Have them produced it yet?
Yeah I’ve seen that kit, not worth it to me honestly. It’s fast enough with stock turbos. I’ll never go Meth either because remember drugs are bad, even for your cars. Thanks man, you’re knowledgeable, cheers.External wastegates would be a partial measure, as they would relieve back pressure buildup, but also throw away that energy vs. using it more effectively. Welding a larger diameter section in place would seem like the obvious workaround, but I haven't seen anyone do that.
A new set of manifolds would be the true fix, and I wouldn't expect it to be that expensive, but the low volume of our cars (and therefore fewer potential turbo-swappers) make it harder to recoup the development costs. The only examples I've seen are from Lap3, available as part of their $12k turbo upgrade kit but not separately:
Stinger/G70 3.3T Twin Turbo Upgrade Kit | LAP3
The world's most powerful build What is included- Twin XCarget XT26 Turbo- Twin Turbo Housing- Twin Turbo Manifold- Twin Tial MV-S Wastegate- Twin Downpipes- Custom Oil Lines- Custom Coolant Pipes- Charge Pipe- Intercooler- HKS Blow Off Valvewww.lap3usa.com
That's a lot of money for 600whp.
Damn bro you found it, that is what we need. Already prefabricated for the exit port and yeah probably would sell way more of these than the full kits.These are what we need (left side).
I wonder if @LAP3 Performance wouldn't make more selling (dozens? hundreds?) of the manifolds alone for $1000 or whatever, vs. the full kit that I can't imagine more than a handful of people can/will buy...especially since the development work is already done.
Smoking fools is always fun and the stinger stock is still very good.Instead of dumping $12k + labor into the Stinger, you'd be better off just move on to another platform. Stinger is a GT car, and that much HP/TQ will just write checks that the rest of the car can't cash... unless, of course, all you care about is smoking some unsuspecting fool on a roll-on freeway grudge match.
Well hang on...where would you fit a BIG rear mount turbo at the back of the engine on one of these?Are you talking about mounting at the rear of the engine, or rear of the car (remote turbo setup)? In either case I'm not sure what problem it's solving...
Stock manifold/housings are a severe bottleneck up high, and if you're going to fabricate new ones, you'll probably just want to swap bigger turbos into the existing layout and move on to the other limiting factors (fuel, head studs, maybe transmission).
