General_Vodka
1000 Posts Club!
Where the blow off valves sit.Paid $419. Merge pipe is metal, if you are referring to the dark grey pipe going to the throttle body. not familiar with the term![]()
I want to say there was some discussion about this a while back. If I remember correctly, the older builds had metal and they switched to plastic at some point. I’ll see if I can find the thread.Where the blow off valves sit.
Found this one:I want to say there was some discussion about this a while back. If I remember correctly, the older builds had metal and they switched to plastic at some point. I’ll see if I can find the thread.
I wonder if it was for performance or cost savings.I want to say there was some discussion about this a while back. If I remember correctly, the older builds had metal and they switched to plastic at some point. I’ll see if I can find the thread.
Starting with MY 2019 some Stinger GT have the plastic merge pipe. I owned 2 model year 2019 and 1 had the metal merge pipe while the other had the plastic one.Also what's up with your merge pipe? Is it plastic?? Or am I just seeing things?
Edit : no it's for sure different than mine. View attachment 40370
Looks like a combination of belt rubber stuck to oil vapour/road grime.What is this black gunk on my engine? Gasket is wearing down or ?
View attachment 40492 View attachment 40493
No oil.Looks like a combination of belt rubber stuck to oil vapour/road grime.
Do you have any oil spotting under your car?
That’s good, well it’s probably like I stated in my first sentence, the area doesn’t appear “wet”.No oil.
yeah my entire engine needs a good clean, its super filthy.That’s good, well it’s probably like I stated in my first sentence, the area doesn’t appear “wet”.
You have a photographic record now so I would wipe it all off, clean the area & monitor it & check every week for change.
you posted WAY better picture on FBStarted to instal these with the very helpful non existing instructions...View attachment 40500
I'll probably do a proper write up about these soon since there is Zero info anywhere about them.you posted WAY better picture on FB![]()
What am I looking at? "Started"? Everything looks in place (to my unknowing eyesStarted to instal these with the very helpful non existing instructions...View attachment 40500
Red spiral thingWhat am I looking at? "Started"? Everything looks in place (to my unknowing eyes).
Red spiral thing
