Cadimac705
- Jan 18, 2020
Got a second quote for $150. Slim picking in Timmins lolI got a quote here in Ottawa between $100-200 CDN, let me know if you need a reference
The car lovers social network
Automotive components
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
You know what the specs are? I love that.Definitely slightly inside, I would expect just like the Federation Stinger which you can see most clearly in this shot, I love this setup personally, just looking at a different style of wheel, though the Sprint is amazing looking.
Fit flush and perfect?Haven’t had a chance yet to inspect them all but here’s a quick shot
20x9+35 245/35r20
20x10.5+45 285/30r20
Waiting for tires but should fit just like Lucille: Now LoweredFit flush and perfect?
In that post says the setup is 1” taller than stock. You going the same tire size too?Waiting for tires but should fit just like Lucille: Now Lowered
Yup, it’s actually a little less than ¾”, but those sizes are exactly matched front and rear, other tire sizes aren’t as good a match or are smaller than stock, which isn’t ideal when going up to 20”In that post says the setup is 1” taller than stock. You going the same tire size too?
I think there are tire sizes in the sheet for that, wheels and offset’s are fineCould a guy go
19x9 +35 245/35/19
19 10.5 +40 285/30/19
mans achieve the stock height so it doesn’t raise?
Or have to use different offsets ?
So hard trying to find wheels for this car lolI think there are tire sizes in the sheet for that, wheels and offset’s are fine
Will that setup work with stock springs?Added in![]()
I'm pretty sure if it fits with lowering springs, it'll fit with stock. But do your due diligence. I bought my setup from Fitment Industries, and even with considerable back and forth (and kudos to them for putting up with all my questions) it was still kind of a nail biter when it came to actually installing.Will that setup work with stock springs?
This is for 20" wheels, not 19's, you're probably looking at going from 225 to 245 in the front and 255 to 275 in the rear, I would check wheel-size.com from the links in the spreadsheet to confirm aspect ratio for those tires, you'll want to stay somewhere within 26-26.5" overall diameter.I see that 245/35 and 285/30 are the same, but slightly smaller than stock diameter, but 255/35 and 295/30 are the same as each other and the same as stock.
