Daniel @ K8 Stinger Store
1000 Posts Club!
- Oct 24, 2017
Is excited to present to the Stinger forums:
Fella Lightweight Brake Rotors Upgrade
(BUY NOW)
Description:
These Fella kits are designed to improve your stopping performance significantly.
The Fella rotors feature a round pattern with the option for a drilled or slotted cut.
The 2-piece design saves rotational weight giving you better acceleration and even faster stopping.
With more effective curved vanes in a V shape, these further help dissipate heat away from the rotors.
This design improves cooling by pushing cool air from the center of the wheel to where the rotor needs it most.
Fella brake rotors undergo an extensive manufacturing process to ensure the rotors can take the punishment from performance driving.
Whether being used for the street or track, upgrading your brake rotors from the standard rotors is a modification you do not want to miss!
Upgrading your brake rotors will help provide better heat dissipation, allow for even wear of brake pads, and give you longer life out of your brakes overall.
Rotors feature a CNC machined aluminum hat that secures the disc to the rotor with hardware that gives a true floating design.
The hard anodized brake hat is extremely durable, not to wear and scratch like standard anodized or powder coated finishes.
Each kit is sold as a complete axle setup (L & R) to work with the factory or aftermarket brake pads and stock caliper.
Each rotor gets machined, assembled, and balanced by hand to meet high-quality standards.
One of the biggest advantages of 2-piece brake rotors is the rotational weight savings!
Features:
2-Piece Rotors assembled with hardware and aluminum hats
Option to choose front (2), rear (2), or complete rotor set (4)
Full floating assemblies with stainless steel
Available in slotted or drilled designs
M8 bolts vs standard
Anodized rotor hats
M6 hardware
Directional vented, heat treated and coated rotors
~Fronts 350x30mm sized rotors, 8.7kg (19.2 lbs) each
~Rears 340x30mm sized rotors, 6.7kg (14.8 lbs) each
Vehicle Application:
2018-2023 Kia Stinger (3.3T Models Only)
THANK YOU FOR LOOKING!
