Driver
Hello
I'm currently investigating options for running my dashcams whilst parked.
For those that have hardwired their Dashcam to run whilst the engine is off - has anyone had problems with the Stinger complaining about Battery Drain? I'm sure I read somewhere that the car can sense this (under some conditions?)
If you've used a battery voltage cut-off device (PowerMagic Pro, etc)...
A) What voltage are you cutting off at?
B) What sort of run-time are you getting before it shuts down?
If you are using a Cellink Neo (rechargeable battery) or similar on your Stinger...
A) What sort of runtime are you getting?
B) How long does it take to recharge in reality?
C) Hardwired or via lighter plug?
Thanks in advance!
Thanks in advance!
