Do you have a vid of what your exhaust sounds like currently with just the Borla?Yeah. Just looking adding another layer onto my existing Borla. May just wait till Spring when it is warmer and after the rock salt is off the roads.
I don’t have one. But I probably can do one and post it soon...Do you have a vid of what your exhaust sounds like currently with just the Borla?
I’ve been debating whether to get the Jun BL. Currently, I have the Borla and love it. But I think the Jun BL adds another layer of character. I probably will get it.
What I was told about the removal of the primary cats will cause it to throw codes and add to over spooling as I have that with Stronger RC map with only Jun Bls and my Borla, just my experience on this so farI’d be careful w/ primaries, once you do that, you’ll need a tune for sure to prevent overspooling (not sure if JB4 or Racechip can help with that as well), and warranty is even more in the grey area. For me this is where I stop. No need to start messing with the primaries, I think it brings a whole lot of problems and headaches with it that just aren’t worth it. The secondary Downpipes does add a little HP, but nothing like primaries. For me, the sound is worth it more than anything. Just my two cents!
Don’t really want to throw codes. I guess I have concerns from the sensors being removed. I probably will start with the Jun BL secondary and go from there. ThxWhat I was told about the removal of the primary cats will cause it to throw codes and add to over spooling as I have that with Stronger RC map with only Jun Bls and my Borla, just my experience on this so far![]()
I do have a JB4You make a great point about the CEL and potential boost issues. It is highly recommended to have the car tuned in order for the combo kit to function properly. From my understanding, if you have the JB4 or Lap3 tune you should be fine. I personally love the tone and bump in horsepower from the primaries I can sympathize with you on the hesitation to jump into primaries but I have not experienced anyone having any issues with the Ultimate Performance Combo Kit. For some people, it may be too big of a risk than worth taking. I try my best to emphasize that if you are seeking the highest performance modification possible then this kit would be perfect for you.
Any changes to the sound after nearly a year of ownership? I had the same setup installed a couple of weeks ago!
Hey Guys, finally installed Borla S-Type Catback w/ Jun BL Downpipes and I’m in love, it’s loud, you get the pops and gurgles while downshifting, and it’s only going to get deeper as I drive more. Not sure what drone people are talking about because I went ahead and installed tips and took others advice. I’m very happy with the setup.
Have a little rattle with tips against diffuser but it’s only sometimes, will prob trim diffuser slightly to create more room or try adjusting the tips a little by adjusting mufflers, but it’s only sometimes so I think I’m going to wait to let things break in before I start messing with things.
Let me know what y’all think!
Love the sound of a Borla Type S , a cold start can make the neighborhood a bit nervous he heAny changes to the sound after nearly a year of ownership? I had the same setup installed a couple of weeks ago!
Just a heads up on what I originally thought was over over spooling, it was really just the low quality gas I was using for the car since buying it new , After changing brands my trouble s all went away , and no more going into limp mode! The way my Sringers GT runs now , is better than I could have hoped forDon’t really want to throw codes. I guess I have concerns from the sensors being removed. I probably will start with the Jun BL secondary and go from there. Thx
Good to hear!!Just a heads up on what I originally thought was over over spooling, it was really just the low quality gas I was using for the car since buying it new , After changing brands my trouble s all went away , and no more going into limp mode! The way my Sringers GT runs now , is better than I could have hoped for![]()
