Can you post the link to where you got the tips?Installed my system today, here's a quick start up vid.
Is that a cold start? You have the same setup as me and I get a metallic vibration at cold-start for a couple seconds. Anything like that for you?
63mmx89mm for MBRP. 51mmx89mm for stock exhaust
AliExpress - Akrapovic Carbon Exhaust Tip
Yep, cold start. Don't hear anything metallic.
Can someone kindly explain to me what makes the mbrp exhaust better than the borla? I know it's .25 larger in diameter but what else? The mbrp sounds like it's a bit deeper but they say it's less loud than the borla? Thank you in advance.
Thank you for the reply. The numbers I'm seeing for mbrp are literally 50 dollar difference than the borla. The mbrp stainless steel comes out to 1265 cad and the borla is 1306. Is it different cost in the states perhaps?It's 30% less expensive, it's less restrictive, and is less obnoxious. A Win Win Win.
Many are opting for the cheaper aluminized (I think am spelling that correctly) version which is 800ish. If you need the SS, then it's probably a wash? Availability seems to be the issue with this vs the Borla.
I don't think there's really a 'better' when it comes to exhausts, as everyone has different tastes. You just need to balance the sound you want with how much you're willing to pay for it. If you get those right, then you've bought the best exhaust for you, which is all that matters.
I got my stainless steel for $930 shipped from Redline360 - Performance Parts & Lifestyle. They had a discount code 'WELCOME' that knocked $30 off.
Note that the wait time was a month.
Makes sense it would be cheaper in the the states. Unfortunately up here they're almost at par. I'm looking for a deep sound which I believe both should have but also looking for which has more power later down the road for future mods
Nope, no trimming at at all. The tips are exactly the same size as the factory fakies. Just lots of wiggling to get them to sit straight and even.
Do you have the link to the exact tips you purchased? Can't find that width size in aliexpress. Thank you
MBRP - 63mm x 105mm (oval tips)
- 63mm x 89mm (round tips)
Stock (also Borla) - 51mm x 105mm (oval tips)
- 51mm x 89mm (round tips)
Just about every supplier on Ali will have them.
US $18.11 20% OFF|1PCS Inlet (54mm) Outlet (89mm) Akrapovic Carbon Exhaust Tip/Muffler pipe For BMW BENZ AUDI VW Car Accessories-in Mufflers from Automobiles & Motorcycles on AliExpress - 11.11_Double 11_Singles' Day
US $28.7 18% OFF|Car styling Oval Slanted Ak ra povic Exhaust Tip Glossy Carbon Fiber muffler Exhaust tip muffler pipe Tailpipe trims-in Exhaust & Exhaust Systems from Automobiles & Motorcycles on AliExpress - 11.11_Double 11_Singles' Day
I bought them from the second link provided by ecko04 (Grill Factory Tuning Store, size IN 63 OUT SIZE A) US $28.7 18% OFF|Car styling Oval Slanted Ak ra povic Exhaust Tip Glossy Carbon Fiber muffler Exhaust tip muffler pipe Tailpipe trims-in Exhaust & Exhaust Systems from Automobiles & Motorcycles on AliExpress - 11.11_Double 11_Singles' Day. It took them a few days to ship, but it was neatly packed and arrived quickly (DHL).
