The voice search worked fine up until they released V13.0, which is likely what you have on your car. They certainly took their time releasing the Canadian market 13.5 update.Just ordered the map update. Kia Canada is going to reimburse the cost since the local search voice function never worked from the start. Apparently this issue has been resolved. Has anyone tried?
Just installed. The local voice search now works perfectly.The voice search worked fine up until they released V13.0, which is likely what you have on your car. They certainly took their time releasing the Canadian market 13.5 update.
Let us know if it's resolved once you get it installed - that's a deal breaker as far as many are concerned.
MNSoft Map/Software Update 13.5 - Canada
Excellent - thanks for the update!Just installed. The local voice search now works perfectly.
Apparently, yes ....Anyone else get the email that map updates are now free for 10yrs but limited to 2 annually?
This is simply a map update, correct?
I’m assuming it still doesn’t allow our phones to read and respond to texts unless they are actually plugged into the USB port.
it's the same update you would get if you purchased it outright, including the newest head unit software - they just provide a discount code that zeroes the price.This is simply a map update, correct?
