Drag/Acceleration The Official 1/4 mile track thread.
OK, thank you for checking. I have been thinking about upgrading the intercooler next on my list. You can see in those logs that the higher boost starts to overwhelm it and the IAT actually starts to climb again.
... Sure wish there were some more options out there in the Stinger market.
Hey guys.... ran an 11.995 last night at the track. Took me a run to get used to the BMS Switch (first run went into limp mode, not sure what I did wrong). Second run is when I got that time. Ran a 12.254 without the switch, so the switch is doing some work! Not sure how much lower my times are going to get until I put on some better tires (currently have all seasons).
Ran e30, BMS Switch plus all the mods in my signature line.
@GRich should recieve a 0.5 sec penalty because his car was dirty as heck :p
Just kidding man. Thanks for showing me how things work out on the track. Let me know the next time you go.
My best run last Friday was a 12.209 using JB4 Map 3, BMS Brake hack, E30 mix, and the mods in my signature.
I did a run in map 5 but in one of the higher gears it felt like I may have hit too much boost and boost dropped off. Unfortunately I thought the JB4 was logging on that run but it wasn't.
Lmao.... Very true!!! But she's all cleaned up now :rofl::)
I don't have the car anymore but I did make a bunch of runs in July in 30 degree heat about 85 F. I used straight methanol and with a JB4 on map8 WMI kit and K&N typhoon intake and my version of a brake switch modification with no other mods I ran a 12.000 at 116.4 mph. I was amazed at the difference between 50/50 mixture and pure methanol. My previous best was 11.94 with no interior, no mufflers.
Meaning that the pure meth performed better than the 50/50 mix?
Michael Locke takes the #14 spot with a 12.055@ 115.40
12 of 15 in the 11s
12 of 15 brake snipping
9 of 15 running WMI
Here are the top 15 track times as of Sept 22nd, 2019.
1/4 Drag strip Top 15 times (Official Track List)
1/4 mile time, speed, 1/8 mile time, speed, 60
1. 11.548 @ 122.05, @Crewdawg130, 7.49 @95.66, 1.719
GT2 RWD, Hybrid turbo, JB4, WMI, FFP intakes, Ultimate HFC primary and secondary, FMIC, Drag radials, BMS brake snip.
2. 11.575 @ 119.91 Angel David, 7.45@ 94.17, 1.584
RWD, Lap3 Pro, WMI, DP, MP, FMIC, intake, Drag radials, BMS brake snip.
3. 11.599 @ 118.77, @Kato_the_kia_stinger 7.464 @93.86, 1.614
AWD, JB4 map8, K&N intake, VT snorkel, WMI, 93 octane, BMS brake snip
4. 11.633 @ 120.83, @ScottyCole, 7.508 @94.00, 1.625
GT1 AWD, Lap3 Pro, K&N Intakes, Lap3 HFC, Ark Mid, Borla Catback, UP FMIC, WMI, BMS brake snip, 93 octane
5. 11.711 @120.51, @TorkMe, 7.620 @95.61, 1.909
GT RWD, Tork ECU tune, Tork intake, muffler delete, no cats, fmic. 92/100 mix
6. 11.764 @116.79, @Angel, 7.542@92.18, 1.608
AWD, JB4 Map 5, AP Intakes, SSR Downpipes, SSR Muffler Deletes, Tork OCC, VT snorkel, BMS brake snip
7. 11.800 @ 116.47, @Tonkabob, 7.589 @ 92.89, 1.74
GT2 AWD, Tork ECU tune, Ark catback, JT intake, UP FMIC, E15, BMS brake snip
8. 11.921 @ 116.24, @GetStung 7.687 @ 93.26, 1.733
AWD, JB4 Map8, WMI, Secondary CAT bypass, Borla catback, Injen intake 93 octane + E85, E30, BMS brake snip
9. 11.946 @ 116.04 @C Mandy, 7.683 @91.08, 1.671
K&N typhoon intakes, JB4 ,Map8 WMI, 94 octane, mufflers removed, secondary cats hollowed out, interior removed (pass seat rear seats spare tire parcel shelf). and a hybrid version of the BMS burnout switch
10. 11.948 @ 118.11, @STINGER, 7.77 @ 92.99, 1.89
RWD, JB4 map 3, WMI, VT Snorkel, K&N Drop ins, High flow CAT, JunBL mid EVC cat back
11. 11.959 @ 117.80 @Kinvara8017, 7.75 @ 93.28, 1.838
GT2 AWD JB4, WMI, UP FMIC, throttle body, VT snorkel, BOV, Custom primary cat back straight pipe exhaust, brake mod
12. 11.995@Grich 116.71, @XX 7.742 @ 91.26, 1.73
GT1 AWD JB4 map 8, WMI, K&N Intakes, Borla catback, Jun BL dp, BMS brake snip, E30
13. 12.022 @ 117.42, @Stinger33 7.82 @ 92.85, 1.94
RWD, JB4 map6, JT intake, JT exhaust, Throttle body, GFB BOV
14. 12.055 @ 115.40, Michael Locke, 7.771@ 90.71, 1.761
GT2 AWD, Lap3 Pro V2, Ingen intakes, mid, Ark catback, BMS brake snip
15. 12.080 @ 115.37, @twn2rbo (Brian B.), 7.80 @ 90.75, 1.754
GT AWD, JB4, Injen intakes, SSR mid, Stillen Catback, BMS brake snip
Rob Banaga on the list at #14 with a 12.04, no snip and recently dyno'ed at 500 WHP.
Here are the top 15 track times as of Oct 17th, 2019.
GT2 AWD, Tork ECU tune, Ark catback, JT intake, UP FMIC, E15, BMS brake snip (11.86@ 118 no snip)
14. 12.049@ 118.35, Rob Banaga, 7.890 @ 93.10, 1.945
GT1 RWD, Lap3 Pro V2, injen intakes, mbrp catback, ark mid, snow stage 2 WMI, E27
15. 12.055 @ 115.40, Michael Locke, 7.771@ 90.71, 1.761
GT2 AWD, Lap3 Pro V2, Ingen intakes, mid, BMS brake snip
Lol. Nobody has really hit 500whp yet on stock turbos. That was from one of those BS dynocom’s and they run ~30whp higher than comparable dynojets. Probably closer to 470whp especially if he’s still only running close to a 12.1.
It’s a shame some people are spending another $1200 to upgrade to the V2 but even with cooler weather it’s still slower than a similar modded JB4 Stinger only using map3.:confused:
They haven't been released yet, but I'm very interested to see what the car will do with LAP3's turbo upgrades and ECU tune... supposedly 620WHP. Hopefully some brave soul will buy it and do some runs. I want to see track slips!
Lap3 offered the turbo upgrade to me. :) I'll pass for now.
Someone in Korea reportedly ran 11.4 but I don't think the slip has been seen yet. But since we are already hitting 11.5 on stock turbos I want more!
Exactly! If the car isn't getting into the 10's I'm not sure it's worth it.... well, depending on price point. But I'm sure it will be no less than $5-6K, which I wouldn't spend for 11.4
FYI-#14 and multiple people I know are already running the lap3V2. Don’t hold your breath because they have been working on the full ECU tune for almost a year and still haven’t released it in the USA.:rolleyes:
Totally agree and only 0.1sec quicker than a JB4 Stinger with a couple bolt-ons is definitely not worth it. And pretty sure they were looking for about $15k for the big turbo kit which is ridiculous for that little of a performance gain.:confused:
As others have said - figure $15K for that upgrade. And THEN a transmission rebuild.. No way the transmission holds 620+ WHP if you plan to run at the track a lot. And if you're going to dump $20+K into this car, you should have probably bought an M3 anyway..
But you will be way faster than an M3
and tuning that M3 is gonna cost big money.
not to mention that you would still have spent less on the Stinger (cost of the car + mods), than the guy who bought the M3
But we are already quicker than an M3 with just a JB4 and couple bolt-ons for only about $1k.:thumbup: Why pay another $14k just to lose daily drivability and be 0.1-0.3secs quicker in the 1/4m.:rolleyes:
What does an M3 + jb4 + E85 do? I saw a dyno of Payam's M4 (older gen?) with just some pipes + intake + jb4 + free flash + E85 doing 580 whp, 630 wtq and he said could easily do 700 tq... Maybe $2k into an M3/M4 to be faster than a Stinger?
And what if that m3 gets to do the free BEF flash + E85 + jb4? That's probably enough to keep up with the Stinger..
