Wheel Nuts with Fast FC04 Rims (Canada Winter Rims)
False, I've bought the +40 offset, they're installed since 2 weeks and they fit perfectly.
Good to know as I'd heard otherwise, are you on FC04's or another style wheel?
I'm curious why you chose the +40 over the +30?
Fast FC04 Titanium 18x8 +40mm. Why ? When I've check the resulting position of the wheels in a wheel offset calculator, the +40mm offset give a more similar position comparing to the OEM than the +30mm for the rear wheels. For the front, it depends if you want the wheels to be 4 mm extended comparing to the OEM or 6 mm retracted comparing to the OEM.
Definitely get the +40mm offset for the winter. Summer I would get the +30mm offset. Will be a direct fit in the back and a -6mm fit in the front. You wouldn't want to be flinging snow up with tires extending out. They are guaranteed to fit over the brembo breaks.
I have the +30 for winter, they look nicer because they fill out the wheel wells a bit more and I installed the splash guards and never had a snow throwing issue with those on. You might without them though.
