I covered everything you can see In the wheel well. I didn’t pull off the side trunk panels; just did the floor, the sides of the battery/tire well, but not under the battery.@Rynil2000
This is exactly it, thanks so much!
How much of your trunk did you deaden? Some part of it looks pretty hard to get to.
I’d rather buy intakesI would get some aftermarket tips , it will look better too![]()
I mean, kind of makes sense that Borla would cut the tips a bit short. They want you to buy theirs.I recommend getting some new tips - you can either get them welded on or secure them using exhaust clamps. I have tried all of the above suggestions and the tips made the biggest difference by a substantial amount. I previously had the Borla with stock tips, and now I have added downpipes with the new tips and it is still quieter than it was before.
I just bought some round tips from Ebay. Made sure they were the right inlet size (57mm), then cut a couple of notches using an angle grinder and secured using exhaust u-bolt clamps.
You must have stock in a pipe wrap company, lol. This fix gets posted every time this problem is mentioned. No doubt it probably works, but I don’t want to jam wadding in the hole as it just looks like a quick fix and not a long term solution.Just do the $12 DIY drone fix like I and many others have done. 3.3TT - Kia Stinger Aftermarket Exhaust Information and Discussion
Works better than the metal plates and saves a lot of money compared to new tips or sound deadening materials.![]()
Side note - over in this thread - users have found some carbon fiber Akrapovic oval tips on AliExpress or ebay that fit right into the stock cutout holes. They look pretty slick IMO. ~$170 for a set of four (105 x 75mm oval outlet, 57mm inlet for Borla pipes)
Lol, I wish as it would be nice to be compensated for sharing this, but no just trying to help people out and save their money by using a better solution.You must have stock in a pipe wrap company, lol. This fix gets posted every time this problem is mentioned. No doubt it probably works, but I don’t want to jam wadding in the hole as it just looks like a quick fix and not a long term solution.
Welcome to the internetno need to be sarcastic and negative to someone
