Tobstertx3
Texas Stinger Swarm
About 26 1/8 front and rear
I appreciate it.
I’m currently 27.75” front & 27.5” Rear. (With about 1 gallon in the tank]
Khartunerez website states the following:
- Drop Height: 1.15” Front/1.0” Rear (AWD)
That's pretty accurate then. I just filled up my gas tank this morning.I appreciate it.
@ZyroXZ2
Ignoring the looks, what's your thoughts on these after having them installed for 10 days or so? Do you feel any difference compared to Stock with regards to Comfort on regular driving? Any difference when you change to Sport mode and are pushing the car?
Not speaking for the gtf crowd...Did you need to adjust your headlights? Heard a lot of eibach spring owners needing to adjust them due to the aggressive drop. Also did you get your alignment?
I did both methods. Maybe my box wrenches suck, but it was a total pita trying that way and small sockets wouldn’t fit. Screwdriver for me was too easy.Uh oh you are going to stir up the screw driver vs. removing air boxes debate again![]()
If u have gt2 then they can adjust automatically but u have to have the dealer do it. They hook up their computer and it tells u how much off the lights r then they go back to stock specs . Mine were off-1.67”Not speaking for the gtf crowd...
My bone stock gt2’s headlights were already aimed way down before lowering.
I’d think anyone lowering needs to adjust them. It is quite easy. Number 2 Phillips long shaft. It won’t seem like you are making progress turning it. But it is. Takes a while.
I don’t trust my dealer to add wiper fluid. I can turn a screwdriver just fine lolIf u have gt2 then they can adjust automatically but u have to have the dealer do it. They hook up their computer and it tells u how much off the lights r then they go back to stock specs . Mine were off-1.67”View attachment 26568
So if I get the Ark springs on the AWD model will the drop be more even than the RWD? Heard that the front end sits a little higher than the rear from the factory so I’m hoping the springs can fix that. Like you said above I want the car to be lowered, but not too low that it looks aftermarket. Plus I live in Michigan and snow is a thing here so there’s that . The wheel gap on the AWD model makes my skin crawl.
The front doesn't sit higher than the rear: the FENDERS are cut higher on the front which gives that appearance.
While I don't have an AWD, my bet is that it drops more on those because of the way the suspension is set up and the spring rates being different. It doesn't mean it drops the car itself lower than a RWD necessarily, though. I believe AWD might actually sit overall higher to begin with (either due to taller springs or a different spring rate) which is why every aftermarket spring shows more drop on an AWD.
Got it so even if the AWD drops more from the springs, it actually sits about the same as the RWD when the springs are settled. Thanks for the quick response, truly appreciate it.
