So i woke up this morning.. any help ?
So far everything is good only light that's on still is check engine.
Everything else is working normally again , e brake, speedo all that. Think the engine light just has to be reset now. Ill give her a thorugh washing tomarrow. Probably leave light on just so dealer can pull code to make completely sure. But im feeling better about her now. Not freaking out anymore. Lol ill take her (the stinger) for a drive tomorrow early before dealers service centers open and i call them .
Sorry for the scare you received and glad that it was resolved with assistance from the forum, I guess they call it now Collective Intelligence.
We probably all learned from this. If you drive your car for a while, the CEL may even reset.
In any case, have fun with your car going forward.
Collective intelligence or the Infinite Monkey Theorem...
Can't compare the former with the latter, unless you feel you are part of the latter....
Depends on the day and caffeine level.
For check engine light, check the gas cap and make sure it’s on right.
Or go to any auto parts store, and they will read the code for you.
That's an incredible reaction to the sensor being obstructed. Why it would affect all those systems is beyond me.
Dealer called me 1st thing in morning they got the uvo report i made for an appointment. Told me to bring it in asap they'll give a loaner. Gonna take it in to be safe.
All light except cel are off everything seems to still be working but better safe then sorry
Did you ever find out what caused your issue? I had a similar situation yesterday- started with the car not unlocking-it beeps and moves the mirrors like it is doing something, but no unlocking. Got in using the physical key, started up ok and then I turned it off. Radio stayed on and doors still would not lock/unlock. Drove to dealership and most every warning light was on, low power steering boost and car felt as if it defaulted to sport suspension setting. Engine seemed to run as normal. 24 hours later the dealership can’t find what is wrong and is checking wiring harnesses for cracking/issues. This is a new car with 800 miles and I have had the car 3 weeks (old 2018 GT2) - it is completely stock.
Ya after it happened at work and i couldn't disengage my emergency break tow to the dealer.. 3 weeks later. And them replacing a sensor... having a specialist look it forn2 days..
It was a loose ground....
They also checked wiring harness.. no issues.
All it was was a loose ground. Some where they "never would have thought to look"
Thank you. If you find out where that last place to look would be, I would pass that on to my dealership.
I work 12 hour days starting tommorrow till monday. But ill try and call them on a break tomarrow some time see if i can get an answer.
Even more simple than a diagnostic. Very good.
Now, let's see that happen to @ChrisK89. Btw, your car is not "old". The very idea! o_O:laugh:
