robz32
Texas Stinger Swarm
Dual Turbo!!?
Well with twin are we talking identical or fraternal ?, and with bi clearly it’s turbos that like both male and female turbos.
Careful. It's loaded.Biturbo, twin turbo, dual turbo - more marketing jargon from the people on the 8th floor after a 3 martini lunch. Different manufacturers have called them whatever they think sounds sexy to Joe and Jill carbuyer.
Now where's that potato I was promised?![]()
To avoid confusion, and as we've pointed out, bi and twin are primarily marketing terms and are not equivalent to parallel and sequential. Also, the first "biturbo" motor was by Maserati, and was 2 equal sized parallel turbos.Biturbo is a more complex system in boost regulation
Maserati was renowned for being the first to mass market twin-turbo, or in its own word, Biturbo. This picture shows its early 2.5-liter Biturbo V6. Each turbo was supplied by the exhaust gas from the nearby cylinder bank. Compressed fresh air from the two turbos joined in a common intake plenum and supplied all six cylinders. This simple arrangement is still being used by the majority of twin-turbo engines today.
Too bad it was such an utter mess. Requiring that you chain a mechanic to the car for availability at all times...if not simply collapsing in a great huge cloud of rust flakes.To avoid confusion, and as we've pointed out, bi and twin are primarily marketing terms and are not equivalent to parallel and sequential. Also, the first "biturbo" motor was by Maserati, and was 2 equal sized parallel turbos.
AutoZine Technical School
But how do you know if the turbos are bi....Well, someone would have to go complain to Nissan about my 1990 Nissan 300zx Twin Turbo if they think that twin turbos specifically means two different sized turbos that are not twins.
Biturbo or twin turbo; take your pick, but I wouldn't call it a twin turbo if the turbos aren't twins![]()
But how do you know if the turbos are bi....![]()
Biturbos swing both ways, air can go in the impeller or compressor end.
Oh, got it...thanks...lol
Yep totally with you on that oneLook on this forum we are not turbo gender specific ok
Lol
Q?Yep totally with you on that one
Large
Garrett
Bi
Turbo
Quick
