Camber after lowering?
Ek9max
Calgary, Alberta
We're you guys able to get your alignment specs back in order after lowering?
Did you guys wait to do the alignment?
I have been running mine for about 3k miles since I lowered mine. I know I need to do an alignment at some point. Might get the Firestone lifetime
Lowered mine couple hundred miles ago and finally got it on the rack here at work. We were able to adjust the toe on the front as well as rear but only camber in the rear. The rear could use some more adjustment to bring it back to spec but looks like some new adjustable arms will be needed. Front could use a camber kit of some sort.
And you were able to get it close to spec?
Pretty damn close. Good enough for me for now until someone comes out with with some adjustment arms or whatnot.
I can upload the spec sheet if you want.
Hope this helps, unable to print color on the alignment computer here at work.
What options are there for getting camber back to spec after lowering? I cant seem to get less than 2 degrees camber out back and I want more tire contact patch.
You won't get it back to speck, close but no cigar.
Had mine lowered awhile back I was driving around with noticeable rear camber. Attached is the best the suspension specialist could achieve.20190312_162738.webp
Anyone know if the Hard Race parts are available to purchase from a vendor?
Or, does anyone know of any other company offering camber kits yet?
My rears at best are at -2 deg Camber after lowering on GT-F springs. I'd like to get closer to zero myself for better RWD traction off the line.
I too would like to know where to purchase the Hard Race parts...
