So why not buy 19s with more sidewall, if higher sidewalls is what you want?
That is what I am doing.
245/40-19
Changing the outside diameter will mess with the speedometer and might have other more negative effects on the electronic tech. Kia warns not to change the size of the tires/wheels, i.e. the od.That is what I am doing.
245/40-19
Kia says the limit on the A/S 18" wheeled set up is 130, not 137.
And @Salman said he got his up to 170, so the limiter is apparently on the generous side; which only makes sense; Kia can't claim a top speed and have the limiter prevent a car from quite reaching it.My digital display read 134 when it maxed out
Yes... the 19" rims look cooler. Yes... they have better performing tires for summer use. I've seen several threads about pothole damage and 19" rims... likely because of the thinner profile rubber. When you add it all up... are the 18" rims with the all season tires the way to go? Year round use... I'm assuming that they also have a nicer ride too due to the thicker sidewall size. Weigh in... what do you think?
That would throw off the speedo.
Same here. I think that tomorrow I'll make an appointment to get my Michelins and "summer rims" put back on.it finally looks like snow-tire season is done.
You're talking a 1 to 2 mph difference at 80mph.
The difference won't get you any speeding tickets that you didn't already have coming.
Yes. It's one thing to take possession of a brand new car and expect the speedometer to be off by less than 1 mph. But to knowingly bump inaccuracy to 2 mph because you modified the OD of the wheels and tires says something about what you will compromise in the name of "fashion".I've done the math. But that sort of thing still bothers me.
