D87
Edit: I guess it was too good to be true. So it continues. On the drive home I noticed the noise went away when u cracked the passenger window... Whatever that means..
Apparently there are two issues at play. Some people describe the issue as a squeak/rubbing whowh others describe a rattle.
My issue was the latter. I tried taking apart my passenger door and installing hockey tape and foam to no avail. I tried lubing every piece of rubber and still the noise would not go away!
Before my morning commute today I stuck a piece of tape on the passenger side roof molding and the noise has gone away!! I was able to get up to 85mph, cross the bridge, and drive for a full 45m without replicating the noise. I'll double check on my drive home this afternoon but I'm almost certain I've pinpointed the issue.
Obviously the tape isn't a permanent solution but now that I know where to focus on I can take it apart and work on a permanent fix.
