Eibach Sways & Springs
Thanks mate....I might avoid it then too unless ozstung has something good to say hahhah
I think if the wheels are aligned properly and the camber setup the right way it would be better as far as tyre wear but I think it would still be low. I would be interested to actually test the ride height to see if it’s even legal. It looked very low. I didn’t want to panic him lol but no doubt he’ll read this so sorry in advance @Ozstung :whistle:. I’d hate to see a bunch of Stinger owners fit the springs only to get defected later by the highway patrol. I’m sure I read somewhere else where the manufacturer claimed they lower the car by a certain amount but in reality it’s actually lower once they settle. Could be an issue, but at this stage just my opinion not backed with any testing.
I asked the guy at Eibach about the drop on springs and he said 20mm but their product pdf states 25mm.
My dealer fitted my sways & stated that they would not cover any premature wear in associated suspension components, I don’t have a problem with that as they would have to prove it.
I need to ask you @Stinger GT SS that price you got the sways done for must have been for mates rates. No ones come within a bulls roar of that. Im still waiting for "His" call back so we will see if he quotes me the same as you or less for mutiple cars.
Width of front to back wheels from the centre divided by 2 X 33.3 = allowable lowered height according to nsw legislation
Well no, I was actually told it would take 2hrs to change front & rear & pricing is based on their hourly rate which I believe is approx. $125/hr.
Too complicated for me after 6 Crownies today plus more to come at airport.
The back looks like an excessive drop due to the massive camber angle.
To be honest the ride is sweeeeet. But like the others said give it a miss if in doubt @Hemz .
If i can get that camber sorted id be very happy.
You beer hound you. Your new name Shannon Beverage.
Ok thanks mate.
What does the underside of your front lip look like and is the ride height legal?
There is a ton of stuff posted on Eibach Sway Bars by many members in the Suspension section of this forum, in order for you to get an informed opinion, I strongly suggest you have a read though a few of the sway bar posts as some members have given some very good summations on this upgrade.
Ok thanks mate.
The front has dropped by 25mm and looks good. The supposed rear of 20mm is more like 35mm.
Spoke to an agent for king springs he told me they only drop 15mm on the stinger. He did tell me in his view the eibachs were superior in design.
I mean scrapes :p
Ok thanks mate.
Front lip is fine no wear and tear and so it should be we have the 360 camera and radar beeps to guide us.
That wouldn't protect from going in and out of driveways though..that's my concern
Can I ask why you like the springs lowered? And how much were your springs plus installation?
And can I ask why you wouldn't? Haha
Sure many reasons.
1: Not befitting the nature of a GT car, a cars aesthetics is really important to me, but lowering. it's just wrong on a GT IMHO.
2: Looks IMHO ridiculous, particularly with the wheel not sitting in the centre of the wheel arch.
3: Shorter springs means harder springs, which does translate to increased NVH (Noise Vibration Harshness) in the ride.
4: Messes with the suspension geometry, requiring work to get wheels aligned correctly, but depending on how low you go, really may require replacement of other parts such as control arms to get the suspension geometry correct.
5: Given the state of roads in Australia and the fact the Stinger is quite low as it is, there is a risk of suspension bottom out on hard cornering (really don't want this) it could cause loss of control.
6: Increased tyre wear if not thought through properly and wheel aligned correctly.
7: In "spirited driving" Tyres rubbing on wheel arches, never a good experience.
8: Will put extra load and forces on suspension components, and has a material impact to your warranty, this is a huge grey area that the dealer could get away with if for example there was excessive wear on lower or upper control arm bushings, ball joints, or even something as simple as tie rod ends.
9: Generally it will decrease the handling dynamics of the car and as such will mean the car will not handle as well as it would at the original suspension height.
10: Again depending on how low you go, may increase rear drive shaft wear particularly CV joint wear.
I'm a purist, a GT car is comfortable, refined, sporty, performance oriented, but not a hard edged sports car. A GT car should get you and passengers from A to B in refined comfort but also offer the performance and opportunity to enjoy those roads that scream out "Drive Me". You should be able to get out of a GT car after 8 or 10 hours of driving and feel like you just got off your favorite arm chair.
I get it, I understand why people mod cars and I get why people like to look of a lowered car, but boy it will come at a large cost of IMHO reduced enjoyment of the machine.
Cheers Hemz :thumbup:
Sure many reasons.
3: Shorter springs means harder springs, which does translate to increased NVH (Noise, Vibration, and Harshness) (Noise Vibration Harshness) in the ride.
Thanks mate :)
