DaBears4Lyfe
1000 Posts Club!
Having a shit ton of issues going Catless in Chicagoland weather. im talking 20PSI on Stock Maps.
outside and IAT. I am fully catless.When you say temps are you talking about the outside temps or coolant and oil temps? Are you full catless?
Interesting and informative. Wonder if that's specific to the cold weather, or simply a side effect of going catless. Maybe low backpressure or something is confusing the ECU so its unable to regulate boost properly?outside and IAT. I am fully catless.
did you get rid of the dump valves?Having a shit ton of issues going Catless in Chicagoland weather. im talking 20PSI on Stock Maps.
I am, but i believe the IAT were designed to push more boost in colder weather not decrease it. Im 99.9% sure its the combo of cold weather and catless as many are catless. Terry wants me to run a map3 test (which potentially could put me over 28 psi -_-), but im not confident in that. Im going to throw some cats on this weekend see how it reacts, before doing anymore test.Interesting and informative. Wonder if that's specific to the cold weather, or simply a side effect of going catless. Maybe low backpressure or something is confusing the ECU so its unable to regulate boost properly?
Are you running the IAT wires Terry recommended for cold weather?
pmd yaI did you want themExtra motors for you
give to you CHEAP!
I don't understand: why go "catless" in the first place? Added exhaust noise? More HP? And now you have "issues" and you ask why?
Time to get edumacated ...
I believe you're correct, so maybe that setting & cold is causing the extra boost? Have you noticed any PSI difference with that FUD Bit setting off?I am, but i believe the IAT were designed to push more boost in colder weather not decrease it. Im 99.9% sure its the combo of cold weather and catless as many are catless. Terry wants me to run a map3 test (which potentially could put me over 28 psi -_-), but im not confident in that. Im going to throw some cats on this weekend see how it reacts, before doing anymore test.
One of my buddies is also catless with a JB4, but he isnt running into boost issues here in warm FL.
And I agree, if already hitting 20psi stock(map 0?) then do more logs & testing before trying map3. Hope you figure it out as that cold weather should help you run some great numbers and look forward to your results.![]()
I am pretty sure he is saying that he needs to get educated not you.wtf? do you know how to read? Try reading first you jackass. Talking about getting educated? I know what the issues are from. The thread was to see what temps are people seeing that are running catless without over boosting issues.
You go catless because that is the single biggest restriction with the exhaust.
Where did you see me asking for a why am i over boosting?
I think you legit just post to get that count up instead of providing any information.
I agree. Im about 75/25 on thinking that I wont be able to be catless in these temps without a tune, but once I try the cats this weekend to confirm ill get some boostane and try a map3 log.
Do you mean without an ECU tune? Because I'm not sure wastegate control is figured out yet on ECU tunes. Hopefully BMS can get that going on the JB4 to fix these issues you northerners are having![]()
Seriously? Are you just trying to troll, or have you never modified a car in your life?I don't understand: why go "catless" in the first place? Added exhaust noise? More HP? And now you have "issues" and you ask why?
No overboost ever on Lap3 but hey, we got ripped off right ?Correct. I dont think a piggyback can solve it. I do think proper Torque management would help me out though.
I am willing to try additional testing once i feel comfortable that there is nothing else going on. Would be nice if he did finish up those EWG controls but not sure if that will be done anytime soon.
Hopefully I get some Cold TEmp responses on what others are seeing. I know KLR had similar issues but they eventually sorted themselves out. He told me he would try to get a pull this week and log it since he is catless in simular weather.
Nobody said it was the jb4. We dont know at this point.No overboost ever on Lap3 but hey, we got ripped off right ?
