Exhaust Tips
Do the factory tips attach to the bumper or do they just clamp on the muffler as well?
hmmm. Will the after market tips that attach to exhaust and not bumper rattle around?
after market tips clamp onto the exhaust
if you're buying exhaust tips from the Autozone clearance section, probably lol
If you're buying a quality exhaust I wouldn't worry about it.
Top and bottom of all four of the existing holes have to be trimmed. There is still a slight pressure fit with the new tips.
No problems with exhaust burns from being so tight? I bought the same ones and my exhaust shop wanted to cut out the whole bottom part. Have not done that?
Zombie thread resurrector,
The exhaust tips on the stinger are not physically connected to the exhaust (v6 at least, assuming same on 2.0). You won’t get heat damage via transfer.
I have these same tips and the only modification I made was a tiny bit of grinding with a dremel to the bottom of the inside holes. Outside holes popped right in and there have been no heat issues. One issue I have been experiencing is the far left tip rotates a bit over time no matter how much I tighten it down. I'm going to get a heat resistant wrap for that one to make the fit more snug.
That's true for the OEM tips, but on these aftermarket tips you connect them directly to the exhaust pipping.
I have the ArK Grip and left side does rattle on bumper. I'm getting aftermarket tips to fix that.
You could just loosen the exhaust and adjust it.
I assume aftermarket exhausts are using 2" outlets as they all mate with the stock tips? Most of them look about that size. Piping diameter is 2.5" but the outlets look like 2".
Does anyone have these Akropovic tips on an aftermarket exhaust and can confirm that the two inch fits the exhaust?
did you guys mount akrapovic exhaust tip to the muffler pipes?
does it not get hot enough to damage plastic bumper?
Yea, clamps directly to the tips coming out of the muffler. I've not had any melting/warping issues in about a year.
SmartSelect_20190627-144703_Instagram.webp 20190622_203258.webp 20190622_203304.webp Snapchat-326971728.webp
