StungnTn
Where is the best way to run the wiring for evc exhaust from the cabin out?
Also the right side will rub the drive shaft bolts on deceleration or hard left turns. Be sure to check that out with a test drive, and adjust if necessary.
I had it installed, but to run the wiring you will have to pull the spare tire and battery, the grommet is right underneath. That was cut and resealed with silicone, and the wiring was fastened internally to the battery harness.
I plugged it in to the backseat outlet for now. I will wire the smart box later.
That's awesome man! I cant wait to put mine in next weekend.I'm very happy with the Xforce exhaust, it's much louder than I thought. That's probably due to the catless down pipes that are included. Overall, the exhaust tone has a lot of character, and I think I like the exhaust closed rather than open, unless it is under high rpm.
Am I crazy or is the 'open' clip louder than the 'closed' clip?Here's a video, I posted it elsewhere, but for completeness, here it is:
It seemed louder open than closed to me, but no much difference. It also didnt sound anywhere near as good as the ark. This is really lowAm I crazy or is the 'open' clip louder than the 'closed' clip?
Open should be louder than the closed. These exhausts have different character, the Xforce exhaust has more burble and fluttering notes within the exhaust while driving, and less drone while closed. My goal was to have an exhaust that was more bearable with the cat deletes. The difference in volume is probably due to the absence of resonators in the Ark exhaust. The largest difference between open and closed is the drone, and the volume under load at high rpm. I think once I have a lot more HP then there will be a significant difference between the two modes. His car also has an intake, and I do not have my SSR intakes that I ordered back in October ;/. To be honest, if it were any louder while closed I wouldn't be happy.
