DaBears4Lyfe
1000 Posts Club!
They are very secretive.Maybe Lap 3 is compensating via tunning or something.....I am sure they know what there doing....They probably know a lot and are saying/sharing very little......
Terry Seems like the kind of guy to watch his competitor's video and say he didn't watch the video, but indirectly comment on the competitor video..........JKAdmittedly I didn't watch the video, but it sounds like narrowest point within the fuel bucket is 3.6mm based on the replies here? Depending on the fuel pressure and how long fuel has to travel along the narrowest point it may or may not be significant.
I still think the first step towards evaluating the fuel system is to get low pressure logging active so we can confirm the higher power high fuel pressure drops we see are preceded by a low fuel pressure drop. And better evaluate low fuel pressure overall even in situations where high pressure isn't cratering.
How high of boost are you able to push the car with without meth? I think most are reporting 18PSI? I know some have hit 20+ but that was with meth correct?
For me WMI is not a option, I’ve run it on other cars and do not want to install on my stinger. Having a bit more fuel for higher E85 and boost would be a huge bonus.
My 300zx had one of the newer snow performance kits years ago and was nothing but problems with leaks. That car needed to nozzles on for each bank and needed a T and kept leaking drove me nuts. My second kit on my 240 gave me zero issues was making 650hp at 32psi on crappy Canadian gas haha. I don’t want to do it on my stinger because if there’s any issues with the car having WMI will be much harder to take out fast if needed. I’ve already modded this car more then I thought I was going to so I have to draw the line somewhere....Just curious as to why you don't want to run WMI? I have 0 experience with it and have been considering it so I am curious to hear your thoughts.
What’s about the routing of the fuel lines tru the car ? Does that go out in 30 min ?The BMS kit uses compression fittings, they are leak proof. With the PNP adapter entire kit goes in and out in 30 min.
Any place that had a fitting. The 300zx has two throttle body’s so it’s uses a T. That was the main spot it would leak and also fittings before the jets. They have probably change that style of plastic fitting by now.Weird. I have a stage 3 kit and nothing wrong with leaking. Where was it leaking from ?
I was gonna say, mine aren’t plastic.Any place that had a fitting. The 300zx has two throttle body’s so it’s uses a T. That was the main spot it would leak and also fittings before the jets. They have probably change that style of plastic fitting by now.
This was probably 12 years ago.I was gonna say, mine aren’t plastic.
