Drag/Acceleration Kia Stinger 1/4 Mile Times
Status
Not open for further replies.
However, I do occasionally see some variation in the slope value over the same terrain. Vertical error (altitude) from a top-down GPS satellite fix always has a much greater margin for error than horizontal. I don't really care, as once I've found a level stretch of ground I'm comparing the time, speed and distance measurements (to my own numbers), which show up as extremely consistent for a given session (same temperature, road conditions, DA, etc.).
I wonder if the positioning of the Dragy inside the car has much impact? Say, on the dashboard with a clear view of the sky vs in the arm rest?
What are you using to hold the phone? Tonka.
Don't know what others are using, but I've found that this silicon mat gizmo works great for keeping my phone nicely planted and in my line of sight on the dashboard. When not in use, I store it in the console - I don't want any knobs or plates permanently glued to my nice new interior. :thumbup:
https://www.amazon.ca/gp/product/B075F64Y4J/ref=ppx_yo_dt_b_asin_title_o05__o00_s00?ie=UTF8&psc=1
The only time I really need the phone up there anyway is with the Dragy - the rest of the time the phone is in the wireless charger bay, usually connected to run Android Auto.
It generally needs line of site but it either has enough satellites locked on or not, if it doesn't then it goes off line.
It likely makes a difference. A GPS device gains accuracy with the more satellites it see - that always results in a better fix.
My dragy is on the dash and phone is on the vent with a magnet.
I could see the phone getting the end wrong but for the start you are sitting in one place for a few seconds.
Ok let’s leave Stung time alone .... let’s not freak out guys it’s not a big deal he just ran an 11 pass second on a draggy and on cold weather ... if he runs an 11 second pass at the track with those mods then we can all go bat shit crazy .... only time will tell if he is willing to hit the track
more than willing to hit the track no worries there.
You sir are the men !!! Put all skeptics to rest and end this debate .... not sure where you are located but when will you be able to hit the track ?? Post results ??
Stung I hope I didn't betray you when I snapped a shot of you testing this stuff out? :) Wash
https://www.amazon.com/gp/product/B..._im&ref_=pe_3730140_387977870#customerReviews
Its highly recommended by the Torq Brothers.....:D
Lol hahahaha I love how you call them the torq brothers .... is actually Tork and Matt and John I beleive there not brothers ... John is the shop owner and Matt is his main minion lol .....Again I will stay away from this now .... wash what he’ll man I taught I told about posting this kind of stuff during work hours ....
No changes, just very buried.
Here are the top times as of January 11th, 2019.
1/4 mile time, speed, 1/8 mile time, speed, 60 foot time
New at #8 is @STINGER knocking @Jonnytig off the list. Now the top 10 is 12.1s and better - Finally!
1. 11.78* @118.58, @Tonkabob, 7.63 @94.20, 1.85
GT2 AWD, Tork ECU tune, Ark catback, JT intake, Ultimate FMIC. 92 octane + lucas
2. 11.91* @120.73, @Terry@BMS, 7.82 @94.96, 2.03
GT RWD, JB4, BMS intake, Water/Methanol injection 50/50, Drag radials, wheels. 30% E85
3. 11.98 @118.96, @TorkMe, 7.84 @94.03, 1.95
GT RWD, Tork ECU tune, Tork intake, muffler delete, no cats, fmic. 92 Octane
4. 11.98* @116.81, @Get Stung, 7.77 @92.52, 1.88
AWD, JB4 Map2, Secondary CAT bypass, Borla catback, 93 octane
5. 12.07 @ 116.73, @Crewdawg130, 7.85 @92.65, 1.90
GT2 RWD, JB4 map3, intake, Ultimate HFC primary and secondary, FMIC, Drag radials. 93 octane
6. 12.07* @ 113.98, Michael L., 7.89 @92.70, 1.95
AWD, Lap3 pro Map3, Injen Intake, no cats. 91 + E30
7. 12.13 @116.78, Jesse P / turbokits.com, 7.89@ 91.51, 1.87
AWD, Lap3 pro Map 3, Intake, FMIC, no cats, 93 octane.
8. 12.13* @ 118.80, @STINGER, 7.99 @ 93.89, 2.07
RWD, JB4 map 3, WMI, VT Snorkel, K&N Drop ins, NGT primary, JunBL mid (no cats) EVC cat back
9. 12.13* @116.6, @KLR STINGER
AWD, JB4 map2, Intakes, Velossa snorkels, Magnaflow Catback, JT FMIC, Lap3 primary dp, JunBl Mid (no cats), Magnaflow Catback, 94 octane e20
10. 12.17 @114.71, Kia Bahrain (@STINGER driving)
GT2 RWD Lap3 Uncle, junbl cat back, 100 octane
Just wondering what's going on with these logs? Did 3 runs tonight. First was map 3 bogged out.. 13.5. Second ran map 2. 12.78 3rd map 3 bogged out again.. 13.5.. here are the runs.
o_O
Your IATs never see under 100 degrees. Check every connection from your motor to your turbo and IC to intakes and don't run another run until you figure it out. Your car is straight up overheating and that is pulling ridiculous amounts of timing.
Hits 130 degrees. Be safe out there boys. If your car doesn't feel right check your logs and figure out what's going on before you keep running it hard. If you need help you can message me and I'll try to help. I'm no tuner but I can read a log and help come up with some maybes!
Unless you're literally doing 1/4 miles in hell. Or letting your car bake in the sun before each run. Then just stop doing that.
I see you are in FL, but I agree those are high IAT’s. What other mods are on the car?
If none beyond bolt-one, it’s pretty apparent that your 93 octane is not enough for Map3. Due to your humidity and FL temps, you’re going to need a new FMIC, and you’d be a perfect candidate for WMI. Your car is pulling a lot of timing on Map3... simply. It hates it.
What all have you done to the car? I know in NC during the summer it’s hard to keep IAT much lower than 95-100. But you guys have more humidity and normally less peak temps... so I would think after allowing the car to hit operating temps you could maintain 95*.
Also @CFLGT2AWDStinger have you posted the logs to n54? Annnnnnd this would have been better placed in the JB4 thread where it would be found quicker by @Terry@BMS ... which will now be found lmao.
I ran a several heat soaked in town 3.9s 0-60s with 95 degree IATs during tuning testing yesturday. Octane is proabably more of the culprit than the heat. But heat certainly doesnt help either.
@robz32 no changes this week.
The facebook group
"3.3t/2.0t perfomance discussion"
Is starting a dragy 1/4 mile list if anyone is interested in getting on that. (No "r" in performance)
Here are the top times as of January 19th, 2019.
Status
