So is that normal then Terry ? When this happens would the car feel like is jerking between gears ? Just curious
You can't feel it since it's not having any effect on manifold boost. The throttle movement in this instance means boost is starting to get close to boost target, as it approaches target throttle moves to intercept and regulate manifold pressure. Boost has to go significantly over target to get significant throttle closure that you might feel. It's all normal and working as it should be in the log.
Tonka's throttle closure issues or whatever he has going on with his flash tuning might be entirely different, I haven't seen useful data to offer a theory on his car.
