AV8R
5000 Posts Club!
- Dec 13, 2017
- Location
- Perth, Western Australia
Eject button is for the people who dont have sway bars..lolwell it does have launch control doesn't it ?![]()
hey I wear glasses and I can see the labels just fine, maybe get your Black felt marker and go over the lettering in black?The white-on-silver LABELING of the navigation keys is virtually illegible during daylight hours. It constitutes a safety issue, as there is distraction when trying to locate the desired key. View attachment 15643
I'm wondering how Kia fixed your car to allow it to stay in manual mode? The Stingers gear box at least on mine. (the 2018 GT model) does not allow me to stay in manual mode for more than 8 seconds when not on the gas? As along as im accelerating or decelerating it will remain there. It was a common complaint amongst Stinger owners.My Canadian Stinger is connected to the internet 24/7. I had lots of beefs about the car I took delivery of in November of 2017. However Kia fixed them October 15, 2018. They won't admit it, but my car got new ECU programming that made changes primarily to the suspension, motor and transmission. Sport is stiffer and now acceptable for a street performance car. It was too soft before October 15. The transmission kept shifting back to 'D' from manual mode and now it doesn't. Since October 15 it stays in manual mode until the car stops. Only then does it go back to 'D'. In auto mode the car was never in the 'quite right' gear. Now, since Oct 15, I can leave it in full auto mode and drive the SH.. out of it and the transmission is bang on perfect. Always in the right gear and with waaay smoother downshifts. Oh yeah, now the KIA logo is popping up in the heads up display when I start the car and the graphic in the Driver Attention screen is a blue chart. Both new features since October 15. Finally, I have more time to give the unlock button a double tap to unlock all doors. Before Oct 15, I had 1 second or the second tap relocked the car. Now I have about 5 sec.
What do I still want improved?
- The headlights on low beam point too low. I understand you can't adjust them. They need to be inclined 1 or 2 degrees for appropriate reach.
- The brake rotors are not up to the 4100 lb car's demands. Mine have warped twice now and I'm in the market for a performance set of rotors.
- The chassis needs a rear seat bulkhead. The hatchback can stay. But add a removable bulkhead stiffener to take the twisting out of the chassis. ATTENTION AFTERMARKET!
- The gas tank is too small. Add another 60 miles to the range please. Also, the snorkle holds about a gallon. WTF??
- The low pass filter to the subwoofers is not set high enough. It seems the subs only work for 50hz or less. They should be pumping 100hz or less so you can feel something out of them. Source signals rarely go below 50hz.
All told. I LOVE MY STINGER. The car makes all the right sounds. Gets all the right looks. Has a top speed that makes me want to drive to Bonneville. Has the nicest interior on the road, and a body that is downright sensuous!
View attachment 17697 View attachment 17698 View attachment 17699
As long as you’re in sport mode and don’t come to a complete stop, manual mode will be engaged the entire time.I'm wondering how Kia fixed your car to allow it to stay in manual mode? The Stingers gear box at least on mine. (the 2018 GT model) does not allow me to stay in manual mode for more than 8 seconds when not on the gas? As along as im accelerating or decelerating it will remain there. It was a common complaint amongst Stinger owners.
Well bless my cotton socks! I didn't know that. But then again I've probably been in sports mode for 5 minutes in a year. Cheers.As long as you’re in sport mode and don’t come to a complete stop, manual mode will be engaged the entire time.
I thought that was common knowledge. I discovered this on my first road trip, two weeks into owning my Stinger: I drove the entire 2K plus miles in Sport mode and noticed at my first intersection that the thing switched to "D" at full stop; but all other times once I used the paddle shifters it stayed in manual mode (this was several thousand miles before I discovered manual gate on the GT1). The only exception was when I was in cruise control, coming down a steep enough grade that in order to maintain the set speed, the car took control of the shifting and downshifted into 5th gear to hold the car back: then fiddling with the paddle shifters produced nothing; the higher priority is cruise control.As long as you’re in sport mode and don’t come to a complete stop, manual mode will be engaged the entire time.
I’ve also seen a YouTube video showing someone banging off the rev limiter while in sport mode, indicating that while in manual mode, the car won’t upshift if you hit redline. I’m not sure if what I watched was acurrate? To see what happens, has anyone taken the car to redline while in manual mode and not manual shifted?I thought that was common knowledge. I discovered this on my first road trip, two weeks into owning my Stinger: I drove the entire 2K plus miles in Sport mode and noticed at my first intersection that the thing switched to "D" at full stop; but all other times once I used the paddle shifters it stayed in manual mode (this was several thousand miles before I discovered manual gate on the GT1). The only exception was when I was in cruise control, coming down a steep enough grade that in order to maintain the set speed, the car took control of the shifting and downshifted into 5th gear to hold the car back: then fiddling with the paddle shifters produced nothing; the higher priority is cruise control.
(I understand that the MY19 GTs, at least, have had the upshifting "nanny" removed. But the risk of engine damage is still slight even without the car taking over and upshifting. In my case, I am glad for the nanny. Read on.)I’ve also seen a YouTube video showing someone banging off the rev limiter while in sport mode, indicating that while in manual mode, the car won’t upshift if you hit redline. I’m not sure if what I watched was acurrate? To see what happens, has anyone taken the car to redline while in manual mode and not manual shifted?
Thanks for clarifying that @upsidedown , I had a feeling I was correct. I saw the initial review of the carsguide Yellow Stinger 3.3si review and they stated it wouldn't hold manual gate. What I didn't know was it was exclusive to our model and the Gt. Did I hear the 2019 isn't effected by this??Don't get too excited Ozstung as you were right the first time. No one has fixed anything out here and according to a recent question of mine to KIA there are no plans for anything to be done. I think the owners overseas have a GT1 which from what I understand is not DBW like all our Australian models.
Why KIA gave it to the GT1 and not the DBW models I will never understand!
what the heck does "manual gate" have to do with setting up launch control? Why did I do that??
That is true. Originally I tried launch control, forgetting that I had the trans in manual gate. Stupid. The subsequent launch went okay with me shifting, but I thought that "launch control" means "Control", you know? Not, "me do it me self". So will try a bona fide launch control next time: without forgetting and putting it in manual gate. I promise this to myself.There is no way you're going to do a better job at judging shifts than the car itself.
Won’t happen, the car is dead remember.Ok updated wish list from Cali
-Kia Badge delete option
-Active sway bars with cabin controlled firmness
-Deeper bucket sport seats
-Heated steering wheel
-Night vision alert system
-active sport muffler
-dual clutch manual tranny
I would like an option to turn on heated seats/steering wheel on remote start, or better yet have a remote start "preset" where I can choose the climate control and heated/ventilated seat options I want on remote start.
Sounds like maybe the UVO phone app can do this... if we had that option in the US.
^^^ THIS !!! ^^^The white-on-silver LABELING of the navigation keys is virtually illegible during daylight hours. It constitutes a safety issue, as there is distraction when trying to locate the desired key. View attachment 15643
1. Dual clutch
2. More exterior and interior colors
3. Cloth seat options like Porsche Sport textile seats
4. Better exhaust note
5. Heated steering wheel standard
6. Option for full leather dash
7. Electrification
