So I've leeched off other threads for awhile now trying to solve multiple issues that I've had after one specific incident. It seems after addressing each one I'm back to where I began.
The car drove beautifully on the interstate up until I found a screw in my tire. I took it to the closest mechanic where he patched it from the inside. He first shaved down the area of the tire surrounding the puncture and applied the patch. He then put the tire back on the wheel without rebalancing. I experienced wheel wobble at interstate speeds on the way home so the next evening I took the car to a tire and wheel garage that Kia Kuwait recommended. They took the wheel off and rebalanced it. I still had wobbling in the steering wheel when going above 100kph afterward. So the next day I took it to another shop where they said since the wobbling occurs between 90kph and 120kph then the rear tires need to be rebalanced. I had them rebalance all 4. They never showed me the results and did not clean off old adhesive. In fact they placed weights on top of old adhesive on some tires. The wobbling was less noticeable but then I began to feel shuddering in the wheel when braking from roughly 120kph to 90kph. So I went down the "bad pads" and/or rotors rabbit hole. Kia shaved the front rotors and supposedly part of the pads which blows my mind. Anyways braking is slightly less on point but the shake is gone. Now when approaching 120kph and further I'm having wheel wobble again.
I'm tired of taking the wheels to shops because they get scratched and more adhesive is collecting. I want to know if the car needs to be aligned and if that will resolve the issue? The car slightly veers to the right but it's so slight that my mind could be messing with me. Could the wheels be over or under torqued? If the patched tire was reversed on the wheel would that cause a wobble? The wobble isn't so bad that I can't reach 118mph, but I didn't have confidence in the steering wheel to hold that speed for long. Could the patched tire be causing the issue, is it never going to perform the same as before?
Feel free to ask for more details, I'm just describing symptoms that I remember off the top of my head
