GRStinger
Yeah, I had to google “snow’ to see what they were talking about.
The car lovers social network
Automotive components
Automotive Hot or Not
Explore Pet Insurance!
Vehicle hacker protection
Advertise with us!
Timing is everything
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
The Food Order Method
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I'd say ''need'' an ''inclination'' are the 2 biggies for me......I have plenty of time. But I have it all the same.You missed part of my quote - the emoji.I respectfully admire your willingness and commitment to sit down and read the entire user's manual. And thank you for the link. It's also available via UVO. I absolutely reference the manual as-needed for such things as lug-nut torque or engine oil capacity. However, probably like most owners, I don't have the time, the need, or the inclination to read the whole thing.
Here's a tidbit rom Edmunds long term update. This is the first I'm hearing of this feature (mine doesn't do it):
"Here's a little detail that speaks to Kia's effort on making the Stinger upscale: The rings surrounding the climate control temperature knobs light up. Turn up the temperature on one of the knobs (the system is dual-zone, so there are two of them), and its ring briefly glows red. Turn it down, and it glows blue. It's not a necessary thing by any means, but I think it's pretty neat."
Maybe it only shows up in the dark?Nope. Mine doesn’t light up.
...I don't have the time, the need, or the inclination to read the whole thing.
Download the PDF from Kia and read when/where convenient, on your computer or phone.
def didn't read all 50 pages so not sure if it was posted... .
BUG.... if you're on the home screen (displays radio and map) the steering wheel control to move between presets is flipped. So up is down on the list etc.
Weird discovery...but our Sedona is the same way.
When changing the preset radio stations, using the steering wheel controls, if you press down it goes down when set on radio display. But in “home” screen, the down control does the opposite and the stations change going up.
The behavior is essentially that when you cannot see the station list, the steering wheel button direction matches the preset number (up moves it to a higher preset number; down moves it to a lower number). When you have the presets visible, the button direction matches the visual orientation, which is reversed.
It's an ambient light....gives just enough light in the cabin to see the surroundings.What is the little light that shines down 24/7 in front of the sunglasses storage?
Mine does this too, I don't use the auto feature fo this reason........mostly happens with humidity.....we'll see this winter, so far it hasn't done it recently with the cold weather.Also, whenever the "Smart" ventilation turns on it immediately fogs up my front windshield. Seems pretty smart.
The mechanical key is for locking/unlocking the glove box and the front doors. Did you pry the cover off? I think the "cutout" you mention is where you use the key or a screwdriver to pry the cover off (I've never done this). With the cover off, the mechanical key goes in the door lock. Turning it toward the front unlocks the door; turning it toward the rear locks the door. (this is on page 4 | 16 in the manual).So I went t a venue,last night...where I had to lock my firearm in the vehicle, The key only goes in maybe an inch.....so I start thinking whats the rest of the key cut for? I get to the drivers door, there is a rectangle cutout under the handle , but the key doesn't seem to fit/.....so where does the ''whole'' key go?!....I haven't a clue.
