AV8R
5000 Posts Club!
- Dec 13, 2017
- Location
- Perth, Western Australia
I also keep it insulated from heat. Very safe.
I’d have it used in 2 weeks. That’s only about 2 tanks worth.
Yeah the 6th October, soooooo long ago157.9.......aaah the good old days.
What else do you have stashed in your underground bunker waiting for the zombie apocalypse?I keep drums of fuel at home. Bought it weeks ago before prices hike. I have enough for a few months , hopefully prices will drop by then. Bought 98 for 1.68 a litre.
What else do you have stashed in your underground bunker waiting for the zombie apocalypse?![]()
I use it now and then. As I only use Caltex I generally go to Woolworths Caltex and get the 4c per litre off but if I’ve got none or their prices go up I use the fuel check app to see what the other Caltex servos are doing and if cheaper I’ll go there and then use the NRMA app to get 5c per litre off premium.You guys don't use the app FuelCheck to find cheap fuel around NSW?
Yep food, bottles of water, like the Italians I stock up when cheap! LolWhat else do you have stashed in your underground bunker waiting for the zombie apocalypse?![]()
I bet Av8r keeps lots of fuel because his got to run his plane.Wow, that’s a substantial amount, do you use it regularly, fuel goes “off” in time.
Planes are what carpenters use, we professionals call them aircraftI bet Av8r keeps lots of fuel because his got to run his plane.![]()
Besides aircraft run on 100LL you can’t get that at the bowser at your local BP.I bet Av8r keeps lots of fuel because his got to run his plane.![]()
Stap??I knew it too good to be true. "Somebady stap him"
