BMS Pedal Tuner - Review
ChiTownStinger
Portland, OR
Hey Guys! First off I'd like to give a shout out to @Terry@BMS and the guys over a Burger Motorsports. I've been using their JB4 for about a month now and not only is the unit amazing, but the support has been even better! Terry is always open to answer any questions we may have, even if it means repeating himself 100 times (ala spark plug gap :p).
Now on to the good stuff!
Terry did a giveaway on the N54 Tech website last week and I was lucky enough to win the soon-to-be-released BMS pedal tuner for the Stinger. I got the unit installed and can now give some feedback.
The installation took maybe 50 seconds, might be the easiest mod I've ever installed! The unit bypasses the connection on the back of the gas pedal, not the OBDII, which is nice since I have the JB4 installed. Below are some pictures of the unit and where it connects.
r5klciGLSfCzaGd4NXOWwQ.webp fullsizeoutput_29aa.webp fullsizeoutput_29ab.webp
If you've installed a JB4, this will look very familiar. I have WeatherTech mats so I ran the cable underneath to hide it and mounted the unit on the center console so I can reach it easily.
On initial set up there is a calibration process, but it isn't too difficult. BMS made a video about how to do this and it's on their website.
The unit has 3 buttons. The top one changes the drive mode, and the other two are used to fine tune each drive mode. I'm not sure if they have specific names, but I've coined the modes Stock, Sport, Race, and Eco.
When the mode is changed off of Stock, the change is very noticeable! It's worth noting that this unit DOES NOT increase horsepower, it changes the sensitivity of the gas pedal. I will say that it definitely increases the fun factor!
I tried getting some data on how it affects the pedal percentage but had a hard time figuring it out because I don't think the changes are linear. Sport mode feels the same as Stock until about 20% pedal pressure, and then it jumps up faster. Race mode is an instant change once you touch the pedal, which is perfect for the Stinger's Sport mode or manual mode. I didn't like using the Race setting in Comfort mode because of all the gear shifting the car had to do, but Sport worked better.
If you like to be on the other end of the spectrum, the Eco mode is great for coaching you not to gun it at every red light! Eco cuts the response way down. It almost feels like you have to press down 50% to get any kind of power response. If you're looking to save gas, this is a great mode for that!
The BMS pedal tuner is definitely a great add-on if you want more response out of your right foot, or if you're looking to dial in how the car feels in general. The Race mode put a smile on my face more than once with the way it instantly delivers the torque! Thank you BMS for giving us quality products!
Thanks for testing it out! I think a lot of you guys will enjoy it, especially 2L owners. :)
Thanks for the pictures and review. I received my pedal tuner today and installed it in about 2 minutes including the calibration part in the parking spot at work. I went for a drive at lunch and it's working as expected. I tested each mode briefly and can already tell how much fun it will be. I can't wait to continue testing when I have more time to drive.
My biggest dilemma right now is where to mount it.
They are in stock and shipping. Best value out there at $179! :)
Terry I assume that the Stinger pedal has two sensors that the ecu cross checks so in the case of a malfunction the car doesn't do anything stupid
If that is the case does your product allow any faulty pedal sensor output to trigger the same response from the ecu as it would if connected directly to the pedal
And now that an extra device is installed does your product carry out any self checks internally to prevent any issues
The ECU does plausibility checks on the pedal input which remain intact, and the pedal module itself runs two voltages (a high and low signal) for redundancy back to the ECU, and each one is handled separately by the pedal tuner. If either of the two signals doesn't agree or if another plausibility check doesn't match up the ECU cuts power to the engine.
As with any modification though there is always some level of risk involved.
Terry, any chance of package deal with JB4 and BMS pedal tuner? Also, which one do you suggest of the options below...Screenshot_20180930-192219.webp
Pedal Tuner, ordered tonight along w/ the cell phn mount. JB4 Tuner will follow shortly...gotta take it slow with the wifey. She doesn't understand why buy on a leased vehicle.:sneaky:
:rofl:
Just finished putting the pedal tuner on, Terry very nice work...have a huge sh*t eating grin on my face. Feels alive!!
Ok, has anyone tried attaching the cell phn mount? If so, what did you use? Finding it's heavy and the tape it comes doesnt hold and I tried another double sided tape, just ends up sliding off.
mounted it here and it hasnt budged. As a bonus if you fire up your phone camera you instantly have a dash cam that pivots.
Hey guys, did anyone do a video review on this? Like what it actually looks like when you throttle on and off? Also too, any thoughts on long-term here? Just trying not to blow up the transmission if you know what I mean....
@Terry@BMS
Can this module trigger the kickdown feature during acceleration even if the switch is not triggered mechanically? Not sure of how the kickdown is implemented.
@Terry@BMS
Yes, no change there.
