Marc Collins
1000 Posts Club!
There is a known update to the shift logic that KIA has mentioned--anyone have any info about when it might come out?
The initial purpose was to add a proper manual mode to the transmission while in Sport--i.e., it won't revert to "D" when you come to a stop and it won't automatically up-shift when you approach the rev limiter. The programming the car came with is similar to what you would get in a minivan or econo-car. So, the question is while applying the manual mode that should have been in the car from the outset, did they change anything else? Any changes could vary by drive mode and whether you have drive-by-wire versus the traditional shift lever. And they could have adjusted the slightly clunky up-shifts while the transmission and engine are still in warm-up mode. Most people report it only happens when the car isn't yet warmed-up.
Based on long experience with TCU updates in other sporty cars, it will be equally possible that they will screw-up a bunch of things that were better left alone. We need some knowledgeable people to dig into this before it is too late.
