DaBears4Lyfe
1000 Posts Club!
Well I am now in a dilemma. My JB4 has been great to me, but I have been reading reviews and seen the dynos and I have to consider the ProTuner.
Any thoughts?
Any thoughts?
My issue is that the dynos can't really be compared to each other, unless it's on the same car, same dyno, same day. There's nothing yet that would sway my decision from a Jb4 to a lap3. No comparable dynos, no 1/4 mile times, nothing. Lap3 is posting most of their dynos with a primary downpipe which most others do not have.Well I am now in a dilemma. My JB4 has been great to me, but I have been reading reviews and seen the dynos and I have to consider the ProTuner.
Any thoughts?
The numbers are very impressive, I'm just standing by for a user-posted back to back review with real life numbers / slips. It will eventually happen.
Any thoughts?
I independently tested the racechip against the JB4 onthe exact same dyno on the exact same day with the exacts same car. Those two performed almost exactly the same. I also race the racechip on the road against a JB4 w/ fueling RWD stinger against me in a racechip black AWD stinger. The JB4 did pull away but only by about a car length at 120mph. I removed JB4 to install ProTuner..... this is significantly faster.
I’ll be returning to that dyno next week and tonight I’ll be going to a 1/8 mile strip. The same strip on which I ran the stinger with JB4.
Curious, was the RWD car running map 1 or 2?I independently tested the racechip against the JB4 onthe exact same dyno on the exact same day with the exacts same car. Those two performed almost exactly the same. I also race the racechip on the road against a JB4 w/ fueling RWD stinger against me in a racechip black AWD stinger. The JB4 did pull away but only by about a car length at 120mph. I removed JB4 to install ProTuner..... this is significantly faster.
Yes it was running map2. It had the fuel wires and was running an ethanol blend as wellCurious, was the RWD car running map 1 or 2?
@Terry@BMS Here's my question to you. Can the JB4 hit 426 WHP on 93 Octane fuel with no other Mods?
Talk to me about that intake before I order any other intake.Sure, we've made 430-440whp on ~93 octane (91 + a couple gallons of E85 mixed in), at map3 levels. The intake a significant restriction though I'd definitely upgrade that. The BMS intake is affordable and easy to install. Will post details hopefully next week. We won't be doing downpipes on our car as they are highly illegal in the USA. And I don't want the odor at idle.
Also not all dynos are going to read differently. What we cook up in the labs here isn't always going to be what customers hit. So before you take that 426whp as gospel, or whatever we suggest you'll make with the JB4, install and and test it on your own car. And see where you stand.![]()
It could have been another map he was running in not sure I just know it was the fuel wire map. And yes I have meth but it has been off for some time now.Why not map5? lol. Map2 is tame for E30 + fuel wires. Don't you have downpipes, water/meth, etc? Or is it another car?
Sure, we've made 430-440whp on ~93 octane (91 + a couple gallons of E85 mixed in), at map3 levels. The intake is a significant restriction though I'd definitely upgrade that. The BMS intake is affordable and easy to install. Will post details hopefully next week. We won't be doing downpipes on our car as they are highly illegal in the USA. And I don't want the odor at idle.
Also not all dynos are going to read the same. What we cook up in the labs here isn't always going to be what customers hit. So before you take their 426whp as gospel, or whatever we suggest you'll make with the JB4, install and and test it on your own car to see where you stand. And if you record JB4 logs we're always here to help you ensure you're getting as much out of it as you safely should be.
Wow can they do that?Does the JB4 allow removal of the speed limiter like the LAP3?
