Rango
1000 Posts Club!
Awesome, any recommendations when installing? Will be getting my kit in about 2-3weeks. So excited![]()
I prefitted and marked where I wanted to drill holes in the splitter. There are square indentations where you drill the holes. Make sure you use the correct drill bit for the bolts (I test drilled holes in plywood). Applied the adhesion promoter, then tape on the underside of the car bumper after cleaning with isopropyl alchohol and removed the plastic backing. Then applied adhesion promoter on the splitter where the tape would contact it, making sure the promoter would not show after install. Then lined up the "points" on the front of the splitter with the "points" on the bottom of the bumper, then folded it up, towards the back of the car into place. Make sure you line it up right the first time. Once the splitter makes contact with the tape, there is no going back. Then drill through the splitter holes into the bottom of the car bumper. The 3 very front holes of the splitter, I used push pins that screwed in. Just take it real slow and prefit repeatedly to ensure you are taping and drilling correctly. Hope this helps. Good luck.
