The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
You will need a laptop to make the changes.
Believe it's 35 for the data cable.I wasn’t hopping it could be selected on the unit itself oh well. I’ll probably end up getting the Bluetooth adaper then as well. If I buy the basic unit does it come with everything to connect to a laptop?
Thanks!
For the DENSO plugs, what's the proper gap to make them? And I assume they don't come gapped correctly, right?
I sent a log to you via email. Not sure how I would attach it here as it doesnt seem to be an option.If fuel control is working and plugs are gapped properly, not sure what might be going on. No JB4 log was attached to your post.
Awesome ty very much, for all your help!Email to yourself, attach to post. Or copy of phone directly when its plugged in.
Make sure to post your run times and trap speeds!Heading back to the track today. Temps going to be significantly cooler and running map 3 now. If I get a couple good runs on 3 I was considering running a couple on map 5. Currently running 30% E85 rest 91. It appears this recipe is also good for map 5. Do I have to change fuel bias too?
Do you have to change any settings before switching to map 6? fuel bias?I run mine with 4.5 e85 and rest 93, map 5 with no issues on denso plugs at .025 gap and k&n filters. I also started playing with map 6 at 8psi.
