Daniel @ K8 Stinger Store
Authorized Vendor
- Oct 24, 2017
Is excited to present to the Stinger forums:
3.3T - Ultimate Performance HFC Downpipe + Mid Pipe Combo Kit
(BUY NOW)
Description:
Ultimate Performance LLC is proud to offer their new high-flow catted downpipe/mid-pipe combo for the 2018-2023 Kia stinger 3.3L.
The primary downpipe portion features an upgraded flange that bolts directly to the stock turbos, the exhaust port opening was increased from 1.25” to 2.4”!
This kit bolts directly onto the turbos and extends all the way back to your factory, or aftermarket cat-back exhaust.
The entire kit is made from 2.5” polished 304 stainless steel, and back purge TIG welded for the utmost quality.
The kit will WILDLY improve turbocharger spool time, as well as power across the RPM range.
Featuring a 2 piece slip fit construction for easy installation and a direct bolt-on fitment.
These are built to last!
THIS KIT IS NOT JUST SECONDARY MID PIPES, IT'S PRIMARY DOWNPIPES & MID PIPES IN ONE KIT!
Features:
CNC'd flanges and bungs
Magnaflow high flow cats
100% handmade in the USA
All hardware included for installation
2.5" T304 stainless steel mandrel bent tubing
100% Tig welded and back purged for perfect penetration
A bench flash tune is highly recommended for “ultimate performance”
Vehicle Application:
2018-2023 Kia Stinger 3.3T
THANK YOU FOR LOOKING!
