windshield washer nozzle clogged
frenchboy
Hello everyone,
My washer nozzle seems to be clogged.
The pump is working when i try to use the sprinkler but no fluid is arriving on the windshield.
That's why i assume they should be clogged.
I took a look to try to remove then qnd try to unclog the, but it seems to be strange to remove the sprinkler.
I already did that on my previous civic and it was easy but for the stinger i prefer asking you before breaking something.
If someone has already remove the sprinkler my ears are fully opened
Thanks
I've had adventures with the windshield washer nozzles. The TLDR is use them more often. I do not follow my own advice, because I hate spraying my clean car with windshield washer fluid. So my driver side nozzle does get obstructed, and even fully clogged in the past. If you are getting no fluid at all, check your hose to make sure it hasn't come off. It is easy to pull off with a large towel if you are wiping down the engineroom. You don't have to ask me how I know.
Hello everyone,
Thanks
Several users have reported that the windshield washer fluid hose has been disconnected during their visit to the dealership to have the turbo oil feed pipe recall perform.
Have you recently had The left side turbo oil feed pipe recall performed?
thanks to have moved the subject !
No recall for me, i have the 2L
