Wind Booster GT - My DIY bypass module prototype
Brotherspoon
Toronto, Ontario
I dug up a bunch of old photos and files related to this project from August 2024 that I want to share with whomever is interested in this type of thing. This project is not over and I am still developing this, now with a much better design and combination with my own 'brake snip' modification, so stay tuned for that I guess.
I've owned a wind booster GT (GT607L) for a long time and am quite fond of this little gadget. I had it on my '18 GT limited and now on my '23 GT limited. This post is about the customization I have done to my unit and the ongoing development of a higher quality, permanent design to share with the community.
It began when I had the module installed on my '18 Stinger and experienced a few dangerous situations where the device malfunctioned and randomly caused unintended acceleration rise while driving and even limp mode due either a module fault, faulty electrical connection or a significant mismatch between throttle position and feedback signal. I don't know.
I thought my wind booster may have been permanently faulty and removed it from the car. I decided to hang onto it and develop a full bypass back-to-stock relay module to activate as soon as I detect a malfunction. The details of this relay module are what I will share here.
The GT607L.
Back-to-stock bypass means full electrical isolation of the wind booster module from the electrical connector of the accelerator pedal and the electrical connector of the car-side wiring. The standard installation requires the wind booster module be inserted "in-line" between the car-side connector and the accelerator pedal. There are (2) 6-pin connectors passing (6) wires in and (6) wires out (12 total) of the wind booster module. To completely isolate the module from the car-side and accelerator side, an additional 12 wires are needed for a total of 24. This is accomplished by implementing (3) 4PDT (four-pole-double-throw) control relays to handle the switching of 24 connections.
If you happen to have a strong understanding of electromechanical relays, you can skip this next part where I explain the function and operation.
4PDT means four isolated connections (four-pole) "IN" with two (double throw) "OUT" paths each, where each (double throw) has both a normally open (N.O.) and normally closed (N.C.) contact (pathway) to make external connections with. This configuration is known as a "form C" contact arrangement.
Three (3) 4PDT represents (12) "IN" paths and (24) "OUT" paths across all relays. "Normal" is the term used to describe the state of a relays electrical contacts (pathways) when no electrical activation signal is applied to the electromagnetic coil - it can also be referred to being at, "rest". The "not-normal" state describes the other condition, where an electrical activation signal is applied to the electromagnetic coil and the electrical contacts (pathways) physically change internally (changeover) due to armature (linkage) movement. It's important to mention that a form C contact arrangement is non-polarized, meaning the "IN" and "OUT" sides that I described are not functionally significant but rather, intuitively helpful.
To summarize the double throw relay function:
- A N.C. (normally closed) pathway will have electrical continuity from "IN" to "OUT" on the "OUT" (throw) indicated as N.C.
- A N.O. (normally open) pathway will not have electrical continuity from "IN" to "OUT" on the "OUT" (throw) indicated as N.O.
- These electrical states are always inverse of each other
Across three (3) 4PDT relays there are (12) N.C. contacts available. I used these contacts to bypass the wind booster module. In this way the male electrical connector from the car can be connected directly to the female electrical connector on the accelerator pedal. Conversely, (12) N.O. contacts are available and used to connect the same male and female 6-pin electrical connectors (car-side and accelerator pedal) instead to the 6 input and output wires, respectively, of the wind booster module.
Interposing wiring and neat extension splicing is required to make these connections remotely as described.
Four (4) 6/C (6-conductor) cables are needed to make 24 connections to the three (3) 4PDT relays. I used #18 AWG.
I made this proto-board circuit in August 2024. Here you can see the through-hole relays which are Omron KS23051: DC 5V 4P2T 2A. This circuit is powered by 5 VDC sourced from the USB port in the car. To make this work, the relay coils had to be connected in parallel.
Here is the circuit board in a weatherproof enclosure with the cabling brought in with glands. This enclosure is fastened to the left of the steering column, near the wiring penetration to the engine compartment. There is enough space to tuck it away and when secured high and tight it will never touch one's feet and interfere with driving in any way.
I dug up the old layout for proto-board assembly.
Here is the wiring map that I came up with to identify all connections. This is to be interpreted with a left-to-right flow.
Here is the completed assembly, ready for installation.
Here is the wind booster module tucked away with all the splices, the car connection to the module harness is zip tied on top. You can also see the entire cable bundle zip tied loosely to the steering column. This has caused no issues whatsoever in terms of steering impairment, or cable wear. It was pretty much the only option to secure the cabling this high up which is the goal. This has been installed like this since August 2024 and has survived two winters.
This is the control location for activation using one of these illuminated switches. The other one was for something unrelated.
Ok then...
