Wheels , flush / rubbing
Marlon88
I’m looking to buy new wheels and tires. I’m just wondering if this setup would go with my eibach lowering kit. ??
Yep you'll be fine.
Niche is a good wheel almost got those.
And they're easy to clean with that spoke design. That's important too
Thanks a lot man , I ended up getting the 255
I am not sure, if you can fit 9.5 with +35 offset up front. I have 8.5 with +33, and it's very close to the strut.
Is this for sure ?
Absolutely not. I am just judging based on my 8.5 +33 wheel. You really want to make sure it's not too wide for the front.
I'm bad I missed the . 5 part of that was thinking 9 " definitely will work
I have 8.5" wide wheel ET38, which fits with probably no more than 5mm clearance to strut. I can just about guarantee a 9.5" wide wheel ET35 will not fit.
9" wide wheel ET35 has a fighting chance, but it'll be very close. That's to strut on the inside. To fender well on the outside, I have no idea.
I belive I have the exact wheels as you do. Enkei tfr. The reason i put +33, was because i run 5mm wheel spacers. And even with them I can't fit my finger between wheel and strut.
What do you think of those tires I got with a 19X8.5?
Ah yes. I do 5mm hub centric spacers on the front wheels too. I did fit the TFR on directly just to check. I could not slip my index finger in the gap. Not even close. My finger is about 8.5mm thick compressed, so I'm guessing the gap was 5mm or less.
Check out Stance Whells you have them cut to your preferred back spacing and the correct hubcentric fitting for your stinger no rings required.
And they were actually cheaper than most
