can you pls post a tight pic of the damageHello all. I have a scratch in one of the grey painted areas of a wheel. Does anyone know of a good touch-up paint match?
Thanks!
nasty but easily touched up , I dont recall anyone here mentioning a match , I guess you'll just have to buy a few touch up pens and try to find something close , if you find one pls let everyone know . I'm sure theres a few scratched wheels cause by a fumble removing the wheel capSure! Here it is; this is about as tight a pic as I could get without it getting too blurred.
Not the first. I asked early in my "career" here. Never got an answer either. Still waiting …In all these years, I think this is the first time anyone has asked for a match on the wheels. Will be interesting to see if anyone has in fact found one.
Belay that! Those danged things cost in excess of twelve bucks, even over twenty, depending. This is not an area for casual experimentation.I guess you'll just have to buy a few touch up pens and try to find something close
Yes, please. Put the mystery to rest.I believe I still have the paint pen; if so I’ll do a test and see how close it is.
This is an old thread, but did anybody ever figure out what colour matched the wheels the best?Yep, exactly how this happened. Had a flat repaired and this was the aftermath. Not happy about it, but having dealt with having a wheel repaired in the past after damage from a tire shop I’d rather just try to touch it up and move on. Maybe I’d pursue it if things weren’t as crazy right now. Anyway, I had a NC Miata Club before the Stinger, and it had dark grey wheels that were a similar color. Toyota Magnetic Grey was a pretty spot-on match for those wheels. I believe I still have the paint pen; if so I’ll do a test and see how close it is.
Yikes; I never got back to this thread. So I ended up trying a couple of different paints. The Magnetic Grey (Toyota) that I mentioned before was a bit too dark. I also tried Sterling Grey (Ford), which matched a bit better but still isn’t perfect. The O’Reilly near me actually has an in house paint specialist that can color match and mix up small batches of paint, but she was off the day I went in and I never actually went back to pursue it. I’d still like to find an exact match, though; just kind of put it on the back burner for now.This is an old thread, but did anybody ever figure out what colour matched the wheels the best?
That's some high PSI ..Any more comments on the best paint pen for the dark areas of the wheels?
So I got tires at the wholesale club and every wheel has tool marks near the lug nuts from the spinning wrench. And to top that off: the air pressure in the tires when I checked it with the hand gauge (because I couldn't believe the numbers on the dashboard) were 58 psi rear and 54 psi front!!! Like 20-lbs over! The sidewall on the tires said 50 psi max! Never again!
Ended up just sanding and polishing with Flitz. No paint needed.Resurrecting an old thread, just slightly curbed my 2021 Stinger Gt Oem wheelon the silver/gunmetal part.
Does anyone have a color match for that outside rim section?
