wheel fitment question
maxmodder
2022 Kia Stinger GT1
225/40/19 front
255/35/19 rear
19x8
19x8.5
I’m wanting to go with niche m191 wheels all around which are 19x8.5" 5x114.3 et35.
Will these fit with no rubbing using the tires that I have? I don’t know the offsets of the factory wheels.
So 5mm sticking out in the front over stock and 11mm sticking out in the rear over stock won’t have any rubbing or clearance issues? Inner clearance is 7mm less that stock in the front and 11mm less in the rear.
If the calculator gives you clearance you should be good to go; if it shows zero clearance or even threatening poke, you want to be concerned about rubbing the inside of the fender.
(Welcome to the forum, by the way.:D)
