Your fronts are 1.5" wider, so 3/4" inside and out at the same +34 offset. Dropping the offset to +22 shifts them outward by 1/2", so your inside edge is 1/4" further inward which should be fine. Your outer edge is 1.25" further out, which I believe will poke a bit. A common modification to flush out the stock wheels is a 20mm (0.8" spacer), and you'll be almost 1/2" past that.I was looking at a set of wheels that are 19x9.5 +22 & 19x10.5 +12. I was wondering if these would fit on a stock stinger. It mostly the offset I'm worried about. Any feedback would be greatly appreciated
So it sounds like there would be some rubbing on the fronts? if I'm reading what you're saying correctly. The rears would be poking by roughly 2 1/2 inches?Your fronts are 1.5" wider, so 3/4" inside and out at the same +34 offset. Dropping the offset to +22 shifts them outward by 1/2", so your inside edge is 1/4" further inward which should be fine. Your outer edge is 1.25" further out, which I believe will poke a bit. A common modification to flush out the stock wheels is a 20mm (0.8" spacer), and you'll be almost 1/2" past that.
Your rears are 2" wider, so 1" inside and out at the same +46.5 offset. Are you sure +12 is right? That would push the wheels outward 34.5mm or 1.36". So inside easily clears but outside is 2.36" further out (with 0.8" or 20mm from stock being approximately flush).
I think you'll want offsets much closer to stock, but happy to have a wheel guru check my math.
I think fronts will poke out 1.25" more than stock (~1/2" too much IMHO) and rears will poke out 2.3" more than stock (~1.5" too much IMHO).So it sounds like there would be some rubbing on the fronts? if I'm reading what you're saying correctly. The rears would be poking by roughly 2 1/2 inches?
I see. If that's what a .8" poke looks like then I would agree the rears especially would stick out way too much. Thank you for the helpI think fronts will poke out 1.25" more than stock (~1/2" too much IMHO) and rears will poke out 2.3" more than stock (~1.5" too much IMHO).
For comparison here's stock vs. 20mm spacer (0.8" poke). Before:
After:
The post I was looking at was in Houston, TX but the wheels weren't pictured on a car so I just had the dimensions to go off ofI think I saw that facebook marketplace post you're referring to, and if you look closely at that photo of the rear on the car you can see the poke. there's a reason he's selling them so new. while you might be able to get a shop to machine them down to proper offsets, I'd stay away.
If my math is correct, that's 2" wider wheels or 1" on the outside, then going from +46.5 to +20 offset adds another 26.5mm (just over an inch), so the outer edge of your wheels is 2" outside of stock, or about 1.2" past flush.I was close; these are in FL, but they are sold. 20x10.5 with a 20mm offset and you can see the poke even from the photo...I hope they didn't sell to a stinger owner.
