[VENDOR][FS]: Kia Stinger - Velossa Tech Dual Big Mouth RGB "Lit Kit" - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is excited to present to the Stinger forums:
(BUY NOW)
Description:
Velossa Tech Air Ducts are designed to help maximize air pressure recovery while the new Diode Dynamic LED mouths deliver an uninterrupted light diffusion.
Velossa Techs Dual Big Mouth Lit Kit is made with industry-leading Bluetooth-enabled Diode Dynamics RGBW LEDs.
Turn heads and light up the night with the Velossa Tech "Lit Kit" Dual Big Mouth Ram Air Intake Snorkel.
You have the ability to switch your LED colors through either the Bluetooth app or with a controller.
Each kit is manufactured to meet or exceed OEM fitment and quality.
Features:
Designed & manufactured here in the USA
Tested & confirmed in all weather conditions
All wiring included as well as fuse and fuse cap
OEM like fitment (no modifications or tuning needed)
Will have the option to integrate with the new CK71 RGB LEDs
Lit Flares includes Diode Dynamics LEDs, mobile app, & controller
Full kit includes (2) Velossa Tech Gen 4 Snorkels & Lit Flares
Click here to view the compatibility of your existing Velossa Tech Big Mouth Kit
Additional Information:
Installation Information: (
FOUND HERE)
The option for "LED Flares Only" is only compatible with an existing Velossa Tech Big Mouth Ram Air Kit 4th Gen.
If you are unsure if you have a Gen 3 or Gen 4 Big Mouth Kit, please refer to the image here to find out before placing your order.
Vehicle Application:
THANK YOU FOR LOOKING!
The Kia Stinger 3.3T Velossa Tech Dual Big Mouth RGB "Lit Kit"
(BUY NOW)
Description:
Velossa Tech Air Ducts are strategically designed to help maximize air pressure recovery while the new Diode Dynamic LED mouths deliver an uninterrupted light diffusion.
Please allow for up to 2 weeks for your order to be shipped out.
(This product is custom made to order)
Features:
Full kit includes (2) 3.3T Velossa Tech Gen 4 Snorkels & Lit Flares
FOUND HERE)
Vehicle Applications:
2018-2022 Kia Stinger 3.3T
I just installed these last night and I'm loving them! However... is there a way to turn the LED lights off after driving? So far I have had to manually turn it off by popping the hood.
Awesome, glad to hear you installed them last night and are loving them.
That doesn't sound right, sorry to hear this.
Please contact support@velossatech.com and let them know the issue, and they'll get back to you pretty quickly.
Looks like there was a bluetooth issue but I was able to fix it just now. Thanks again for the info though!
So do I understand this sale. You don't get the snorkels just the lighting kit to go on the snorkels?
There are two package options to choose based on your needs. There is a full kit that includes the Gen 4 Snorkles (click HERE to view) and then there is the default option which is for the LED Flares only which would attach to your already installed Gen 4 Snorkles.
Does anyone know why my battery is draining after installing this kit. I've woken up to a flat battery a few times now. I dont use the lights that often but they are always putting out a bluetooth signal. I'm in the UK so connected to the plus terminal on the smaller fuse box. Its the opposite side to US cars?
Sorry to hear you're having this issue after the install of the product.
Usually, the only reason something like this would happen is based on how it is wired to your vehicle.
I would recommend reaching out to Velossa Tech directly for tech support, as they will verify how you have it installed.
Support@VelossaTech.com
If it is related to the installation, they will help you to find another way to wire it to your vehicle.
Can you clarify the compatibility with RGB CK71 lights? Are those confirmed to be coming?
I have not heard of any confirmations on this yet, as soon as we know, we will make sure to make an announcement and update the website.
I guess I’m just wondering why it’s mentioned on the store page, I haven’t seen any mention of it from @Chris71
I (owner of K8 Stinger Store) am very good friends with (Chris) the owner of CK71, and he asked us to list it on our site when creating the product page.
It is something that IS still in the works to happen, just no ETA at this time. A lot of things have happened recently in the world that is causing delays in manufacturing and production.
That is the reason why it is mentioned on our store page, and you haven't seen any mention of it from @Chris71
Excellent, I’m just glad it’s in the works! Looking forward to it :)
Hi I’m having the same issue. Can you share how you fixed it? The app is also giving me issue but my Bluetooth is on and working. Thanks.
Looking for a way to turn heads while you're on the road? Well, look no further!
The Velossa Tech Dual Big Mouth RGB "Lit Kit" will change up the entire look of your Kia Stingers front end.
These Dual Big Mouth Ram Air Kits are made with color-changing RGB LED lights that can be changed on the fly.
Each kit is made with industry-leading diode dynamic LED lights that are top-of-the-line and incredibly bright.
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
