Daniel @ K8 Stinger Store
Authorized Vendor
- Oct 24, 2017
Is proud to introduce to the Stinger community:
KW V3 Performance Coilover Kit
(BUY NOW)
Description:
If you want the best of the best for your Kia Stinger, then look no further, as this is it.
Get the best of both worlds with these fully adjustable and top-of-the-line KW V3 Coilovers.
KW Coilovers have a specialized height-adjustable composite spring seat that allows the ride height adjustment via the trapezoid thread on the coilover strut housing.
The 2-stage independent compression gives you more comfort, improved handling dynamics, reduced body roll & reduced vibration during increased rebound force.
If the Stinger is equipped with adaptive damping from the factory, the V3 kit can be supplied with a cancellation kit that plugs into the factory sensors using a compatible connector that allows all of the other electronic and dynamic assistance systems to remain active.
Specifications:
2-stage compression valve
High-tensile, high-quality racing springs
Stepless & fully adjustable collar sleeve
Limited lifetime warranty through the manufacturer
Completely adjustable at all 4 wheels on almost every vehicle
16-click rebound adjustability & 12-click dampening adjustability
Shocks are designed with a hardened, chromium-plated piston rod
Available with ECS Cancellers for vehicles equipped with Electronic Dampening Controls
Durable V-shaped Teflon seals on the pistons provide optimal sealing, minimal friction, and reduced temperatures
Vehicle Application:
2018-2023 Kia Stinger AWD & RWD (All Models)
THANK YOU FOR LOOKING!
