Tire pressure..
MekstingerGT
So I notice that with lower profile tires 35front and 30 rear my tire pressure reading seems low. In the morning itll go as low as 35psi but after driving it the highest I've seen is 38-39. Seeing that it's been about 60 degrees outside do I have to put air so itll be at least 45-50 per tire max psi? Or just leave because of the cold temp?
The rated “cold” psi ranges are for like 50 degrees and up. Add 3 psi to your calculations in winter
Rear looks low based on your observations.
Normal “cold” PSI specs
Stock 18”
36 psi F, 39 psi R
Stock 19”
38 psi F, 36 psi R
