Tire pressure warning won't go away
Buzzman12
Ottawa, Ontario.
Hi folks.
2023 GT here (Canada). When I took my Stinger for a drive last week, it indicated low tire pressure on the front right tire.
The car sits in my garage for most of the winter, so I wasn't surprised.
I brought the tires back up to 33-34 PSI all around, but the message and the icon will not go away.
The manual says the system will reset on it's own. After driving it again today, with several stops to run a few errands, the message is still there.
Any ideas on how to clear it is appreciated.
I have read about this before. Raise the psi above 40 psi. That should do it. Then after the TPMS resets you can lower it to where you want it.
