Squiling noise coming from A/C inside the cabin
GhostGrey
Whenever the A/C is on there is a faint squelling/squeaking from ONLY inside the cabin. Can't be the drive belt as I checked when the A/C was on by opening the engine bay. Very annoying, what can it be? And what can I do to fix it? It's only when the A/C is on not the fan.
So many moving parts. Where in the cabin is the loudest location? Time to move around and put ear close to vents. Then it's probably a motor. Shooting in the dark here: so will anyone else, unless you're lucky and somebody reading this has experienced the exact same thing and already knows what specifically causes it.
Blower motor
Have the same issue with my stinger. Dropped it off at the dealership, hoping they find the problem. It's super annoying. It's def not the blower motor. More of an evap system sound...
Just had this happen to me recently in my car. It ended up being the cabin air filter cover not sealing/closing up properly.
I used some foam tape around inner part of the cover that seals up with that edge of the cabin filter slot and it fixed the issue for me on my end.
your user icon blows my mine lmfao
