I have seen some talk on spark plugs but have not found much on different plugs. Just stock NGK, DENSO, & HKS. I have Cold air intake and that's it. When I bought the car it had the cold air already. Also Denso plugs. After a couple years the car had a miss. I checked codes and it was misfire on #2. I pulled the plugs and gapped them. While I had the plugs out I ordered like for like. IKH24 5346 on the box. I have noticed a couple misfires again a year later. I am thinking of changing to a different plug.
I checked some specs on the stock NGK 97976 plugs and they are a heat rating of 7 with 14mm thread and 26.5mm reach. I went on the NGK website and they have Ruthenium plugs which is there highest end plugs. Has anyone herd of anyone trying these plugs. Summit racing has them for $11.39. They are heat range 7 14mm thread with 26.5mm reach and gasket seal. Sounds like it would fit?
