Road trip prep
JSolo
2500 Posts Club!
People's Republic Of IL
It's been 4 years since I've gone anywhere more than a hundred miles or so. Going a few states away soon. Given it's a new car, prep should be less than on my older car. I still check the following
1) Jack vehicle then inspect tires for punctures and inner sidewall damage
2) Check oil and coolant levels
3) Top off spare
4) Make sure lights/turn signals working
Take with
a) 12V air compressor (87P Portable Compressor | VIAIR)
b) Rope puncture repair kit & tools (blade, pliers, etc)
c) Tire Gauge
d) Large ratchet w/21mm socket
e) Torque wrench
f) flash light
g) Various usb cables/adapters - Have devices that use mini, micro and C connections
i) Extra 128gb microsd for dash cam
j) Jumper cables
What else?
3) Top off spare
Take with
c) Tire Gauge
e) Torque wrench
f) flash light
j) Jumper cables
What else?
Hmm, I didn't do any of those things, aside from having a pressure gauge. But my car had just had service so I was feeling pretty confident.
Always bring water and food just in case.
I'm more like Devin in this. I get my car checked out, oil changed, fluids checked and topped up, tires checked. And then I go. Tools? Just enough to get the spare on.
Instead or in addition to jumper cables, nice to carry a jump pack. Helps if nobody around. I carry the Hulkman Alpha85. Fewer and fewer people care to help others...
I only have the jumper cables, never actually had to use 'em.
If it's something simple, I may try to fix it on the side of the road (tire). Otherwise try to be reasonably prepared.
This is me traveling light. Still there's a plug kit, compressor, some tools, a netbook, clothes, shaver, toothbrush, and some other crap.
Work gloves or rag to wipe hands off so you don't get your interior dirty after changing a tire.
I always bring water and some protein bars just in case. AR15 is nice to have as well, or at a minimum a Glock. JK on the weapons....sort of.;)
I have those, lots of rags. In fact my entire ONR wash kit goes with me on road trips. I stop in a grocery store and buy a couple gallons of distilled water. If I'm visiting family I use their washing machine and dryer, otherwise I find a laundromat to get my towels ready again.
I keep a set of those and a small plastic tarp in one of the recesses in the spare tire cover just for the chance that I might need to change a tire.
Depending on how long the trip is, changing oil before you leave might be a good idea.
