Removing rear hatch carpet
Transmetal
1000 Posts Club!
Anybody remove the rear cargo carpet? I had an unfortunate and unexpected event happen to my car. Need to get to the metal on the driver's side. Was hoping that there's a quick and easy way to remove the carpeting without having to pull all the rubber trim out and whatnot.
the top carpet pulls right out ?
I assume it is glued in. You can probably use a hair drier or heat gun and pull it off and then when it is time to reapply, clean it with a solvent like paint thinner or mineral spirits and use a spray adhesive on both surfaces to adhere it.
oh the side panel ? remove lower carpet , remove 4 10mm bolts and snap it out of place
There's no carpet in hatch area. You remove capreted side panels and all the covers from the floor. That is it.
Sorry, I meant the side panels that have the carpet like material.
Mostly just clips. - Use a trim tool or similar.
I do not recall there being any hidden fasteners.
See image for hole locations for the clips
other side for good measure
Thanks! I'm assuming you have a gt2? Which is all the electrical components on the driver side?
I have a base gt. So no smart trunk. I wonder can you just remove the side panel without taking out the rear piece that has the silver piece. Just trying to make it easy as possible without disassembling the entire area. This is why I'm asking about all this.
Wanted to access the inside metal so I could temporarily put some flex tape on over the hole until I figure out what I'm gonna do. I have Allstate insurance (which I hate with a passion). Literally just replaced my cracked windshield last week. Have full glass so they didn't raise rates for that but out of the blue my 6month policy is almost 200 bucks more than last month. Dealt with a total loss that happened in 2020, which is why I have a Stinger. Don't know if I wanna put this on there to. Rates would probably be unaffordable at that point.
The Stinger has been nothing but great but my luck however, has been a shit show.
I looked at mine again... bolts and clips. That's nifty!
View attachment 67940View attachment 67941View attachment 67942
rear transverse trim (A) - is the piece you are describing.
See here for helpful details.
Also, mine is a Canadian model - GT Limited.
The electronics on the drivers side are the Rear cross traffic collision avoidance sensors and the electronic electronic controlled suspension controller.
Screenshot_20220217-203605_Chrome.webpScreenshot_20220217-203346_Chrome.webpScreenshot_20220217-203026_Chrome.webp
Bruh, did some one shoot your car?
Yep.
Mofo was mad that I brake checked him, cuz he was literally on my ass, guess he decided that shooting at me was the way to get revenge. And I thought I had road rage issues, jeez. Whoever it was is next level sick.
holy crap!
Yep.
That is why i never brake check. The way this country is going, you need to have a loaded gun in your hand before brake checking.
Yes. As frustrating as it is, if someone is being an ass, you can’t get worked up about for that exact reason. Easier said than done of course.
15 years ago I would have been ready to fight. Not anymore.
You almost have to be a lil wuss now a days just to see tomorrow. Not saying i enjoyed fighting, that crap hurts, but people are too quick to shoot. So ill be a lil bitch and walk away. Not worth the chance to me.
Ok, so I don't know shit about auto body repair but I took it to get an estimate this morning. Was told this: Basically that they can write up an estimate for what they see but if there's more damage inside ie: damage to the structural steel that the entire side of the car has to be replaced. So u can't just weld a patch panel in there per say. Was told that mild steel can be welded but structural steel loses integrity with heat so welding isn't possible. I've never heard of this but all I know is what I see on car shows when they are doing car restoration on old cars or building cars, they be welding the shit outta stuff. So yeah, I don't know a damn thing about it.
My main concern is rust starting on the open hole given it's winter and they use all sorts of nasty chemicals on the roads. I can remove the carpet piece and get to the inside but unless I take off the rear bumper then I don't have a way to get to the outside part of the hole.
Sounds like they just f-ing with me. I feel like I could just plug up the inside hole the metal part with something and plastic weld the bumper and call it a day.
Nah f*ck that place, shit doesn't even need to be welded to begin with., it's a small hole they could just fill it with epoxy putty and be done, it's not going to affect the car, the guy didn't shoot it with a anti material rifle. There is some truth in welding structural steel but really, it's a non issue for this small amount of damage., the hardest part of that fix will be the bumper cover and blending paint.
Pull the luggage side trim, and see if anything other than the single layer outer body - non structural steel, was affected.
Soooo....when we puttin a posse together? The more i read the more wtf keeps rollin thru my head. Dude im glad you're ok
