Rebadge after Coating?
funesto
Philly
Hello all! First post here! Excited to be part of the community!
I took delivery on a beautiful Micro Blue GT2 the other week, and took it to a shop first thing to have a paint correction and ceramic coating done. (I went with IGL Kenzo, if it makes a difference).
Now I've found this forum and its all over. RIP wallet :laugh:. Anyway, I really want to do a full rebadge, and I'm wondering if that is advisable AFTER the coating has already cured and hardened? Ideally, I would like the Flying K all around with "STINGER" across the hatch.
Thanks in advance!
Thanks in advance!
Welcome , the new badge for the front is the same size as the oem so no issue , the removal of the oem is the critical part , search that here for tips and insights . The rear may require a touch up to eliminate badge ghosting but again it should be fine . DO NOT overheat with a heat gun , summer heat or a hair dryer is more than enough to soften the oem adhesive tape .............search and research ..
